I create an event to control a dimmer up . I had error when I run. Can your point out where the mistake I make? Thanks.
This is the error I got.
This is the event I create.
IF
This event is MANUALLY triggered
THEN
Set Device Home Hallway HomeSeer HS-WD200 Dimmer Light to variable $$DVA(390): + 1
Legacy-Plugin EasyTrigger ERROR SetDeviceValueToVariable: Cannot parse variable to a numerical value
IF
THEN
