Just installed yesterday. What is the latest version? What is the method to check for updates?
Latest ver.
Select "Setup" from the menu then make sure you are on the "General" tab. (http://192.168.xxx.xxx/setup.html)
If you go to Plugins>Manage, any plug-in with an update will have a little cloud showing an update is available.
If you want to look for possible beta releases go to Plugins>Add and make sure Show Beta Plugins is turned on. Easy Trigger is a legacy plugin.
HS4 Pro, 4.2.18.9 Windows 10 pro, Supermicro LP Xeon
