Can I set EasyTrigger schedule values with a script?
    I'd like to use a script to set the start and stop times of a schedule. Is that possible?
    The schedule parameters are stored in a simple text file. Not at where I can check the filename at the moment, but should be in the /config subfolder. IIRC, each schedule is a separate line. For a competent scripter (I'm not one) it should be relatively straightforward to modify the appropriate line in the file via script.
    -Wade
      Cool!
      What I want to do is this. I want to have a schedule where both the start and stop time are based on sunset. So some time before sunset I'd run the script and set the schedule times.
        I believe ET allows you to define schedule times relative to sunrise and sunset. Check the users manual for details.
          Yes ET allows you to define time ranges relative to sunset and sunrise
          https://forums.homeseer.com/forum/ul...41#post1347341
          You can also change a schedule from a script using the SetSchedule scripting function.
          https://forums.homeseer.com/forum/ul...15#post1281015
