I'm not sure it's possible but I'd love if there was an event trigger for when homeseer or an addon update was available
Easy Trigger plug-in - Feature Requests
This is a sticky topic.
HS4 Pro on Shuttle NC10U, Win10; Z-NET
Number of Devices: 1005
Number of Events: 293
Plug-Ins: BLLock, DirecTv, EasyTrigger, Honeywell WiFi Thermostat, Marquis monoprice Amp, MeiHarmonyHub, PHLocation2, Pushover 3P, UltraM1G3, rnbWeather, Worx Landroid, Z-Wave
External applications: Homebridge-homeseer, Geofency, EgiGeoZone.
Originally posted by andyf View PostAll my Z-Wave battery nodes report a capacity in %. It is possible for a battery to skip % values between reports so having to trigger on an absolute value is somewhat limiting. It would be nice if you could add a "greater than" and "less than" to this new trigger.
Originally posted by spud View Postin version 3.0.0.36 (available in updater in Beta section), I have added "not equal to", "greter than" and "less than" options:
Thanks again.
Originally posted by alexbk66 View PostThis is really great! I have multiple motion sensors for occupancy detection - with the new group option I could remove multiple messy IFs - now have just one event condition!
Thanks again.
Composite Device Status script... https://forums.homeseer.com/showthread.php?t=189986Last edited by Ltek; August 30, 2017, 10:18 AM.
Originally posted by Ltek View PostYou want something really useful... Combine this easy trigger feature with my Composite Devices script
I'm actually trying to write a plugin myself for creating generic composite devices since HS isn't very 'user friendly'. Funny enough I was thinking of 'Composite Device' name for this plugin
But I'm pretty new to HS, so it's a bit of learning to create a plugin
[ATTACH]63043[/ATTACH]
Such as ALL devices in the group Motion are equal to 0 or ALL devices in group Door are equal to 0. Alternately it could be if no devices in group motion are equal to 1.
This would be useful to detect if all motion has ended or all doors and windows are closed.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Can you clarify why my script it is not "reusable"?
Setup is DEAD SIMPLE and only 5 minutes. I've automated more than many plugins do.
The script is can be customized to any use case. with vDevices and variables you can use grouping criteria (based on any text/words the user defines)
BLRadar plugin is totally different than my script. Does others stuff, not what my script does.
My script is made to group similar devices into a single status device while showing (status text) what devices are tripped.
Originally posted by alexbk66 View PostThere's also BLRadar plugin... Regarding the script - it's nor really reusable, unfortunately as it's designed for your particular setup.
Originally posted by rprade View PostWould it be possible to augment this useful addition to include triggers and conditions for ALL items in a group? Unless I am missing something there is no way to do this.
Originally posted by Ltek View Postmy script does exactly what you are asking for
Composite Device Status script... https://forums.homeseer.com/showthread.php?t=189986HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Originally posted by rprade View PostI also use a number of scripts, storing currently open doors and windows in virtual devices. My suggestion to Spud for "ALL" in addition to "ANY" was to make his plug-in have more value for other users. I'm sure there are many who would like to handle this within an event rather than having to create or edit a script.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Originally posted by cowinger View PostWanted to bring this back to see if there is a way to do this.
Originally posted by spud View PostEven if we had a way to trigger based on a sequence of changes, I don't think it would be very user friendly with regular Zwave switch because you would have to wait for Homeseer to see multiples on/off changes.
Counter triggers
Spud,
Is it possible to create a time based trigger for counters? For example, if a counter has been greater than 0 for more than X minutes?
I've searched around the forum for a good way to turn HVAC on/off based on doors/windows being open for a certain amount of time, I've found one that start and stopped a timer but I've also read timers can be troublesome.HS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
weatherXML, Jon00 Alexa Helper, Network Monitor, MyQ, Z-Wave
