spud, the enable/disable works great ... but in the UI
I originally had an action to run an immediate script command &hs.DisableEvent.
When I changed it to your Disable Event it did not clear the script command or ask for the event to disable. I had to delete the action and add a new one. Note. that if you change Control a Device to Disable Event it works fine so I assume it's just immediate script command that fails.
When you bring up the dropdown list of events I don't suppose you could sort them like in other actions. The list of events seemed to be in a totally random order making it very difficult to find the event you want.
in version 3.0.0.43, the list of events is now sorted alphabetically
Great. Seems they are still not sorted on the Config page, would be nice if they were sorted there too. Now they seem to be in the order entered, would be nice for example to have all Garage entries next to each other.
My request was for the list of "Events" in the Enable/Disable events actions which spud has fixed.
I believe that what you are requesting is to sort the list of devices within a device group or just to sort the list of groups?
Today i wanted to try make a event and i see it is missing 1 thing i really need.
Can you add this two : The device string was not changed for atleast xxx minutes The device string contains xxx and was not changed for atleast xxx minutes
Thank you
