Easy Trigger plug-in - Feature Requests
This is a sticky topic.
  • Originally posted by kideon View Post
    Could you add the trigger for if a device has changed within the last xxx? I was planning on using this specifically for some occupancy scenarios like if the phone status changes to online and if the location has changed to near home within the last five minutes then change to home. Another scenario would be if motion is detected and the doors have changed status in the last xxx then xxx.
    I could add conditions based on "last change date" like "last change date for device X is within Y minutes from now"
    • Originally posted by spud View Post
      That would be great! With that, rock solid occupancy detection will be in my reach. Would it be possible to include the potential values like door sensor changed to “open” within the last xxx minutes/hours/days/seconds?
        Yep that's a good idea, will do it.
        Excellent! I am really looking forward to seeing what I can do with this new feature.
        • Would this allow us to piece together long messages? I’ve been working on my announcements and thinking of creative ways to do that dynamically without chained events.
          • @spud, I see we have the option of "A device's value has NOT changed for exactly...". Can we get "A device's value has NOT changed for at least..."?
            I ask because I want to monitor a device to see if it has not changed in 24 hours. I also want to be notified on an hourly basis after that. If I use the trigger that's in there, I only get the first alert. If you can add the one for "at least", then I can set the event option "Cannot Re-run for XXXX" to 1 hour.
            Would this be simple to add?
            Frank
            • Originally posted by sirmeili View Post
              You can do it using a recurring trigger and the ET condiion "A device's value has Not changed for at least"
                Good idea. I've never used recurring triggers so didn't think to use it here Thanks for the heads up.
                Frank
                • in version 3.0.0.45 available here I have added 4 global variables (ETDeviceRef, ETDeviceName, ETDeviceValue and ETDeviceStatus) which are set with the triggering device when a group triggers.
                  This allows to do some things like the following:
                  • Comment
                    • This is already there, there is a +/- field that you can use as an offset for the comparison trigger/condition
                        in version 3.0.0.46 available here, I have added the condition "This device's value has changed within the last..."
                        • Is there a way for a plugin to extend the device to add a new database field?
                          ...a user definable Device Category would help.
                          ... built-in Device Types aren't standardized / consistent and not really usable for sorting or use in events
                          To help fill the gap, I've been using:
                          Composite Devices script I posted
                          - creates dynamic (on-the-fly) device groups based on any combination of location fields, device name and device type
                          Easy Trigger plugin
                          - Device Groups (static) or a single device filter uses in events
                          Sent from my SM-G950U using Tapatalk
                            Nice.
                            Any thought on the Global Variables being added to capture the qualifiers of the event, not just the trigger?
                            • Would it be possible to have it be this device has changed to ... within the last ... and present the options for device values?
                                can't you just add an additional condition?
                                AND IF device's value has changed within the last...
                                AND IF device's value is...
