Easy Trigger plug-in - Feature Requests
This is a sticky topic.
  • Originally posted by spud View Post
    in version 3.0.0.46 available here, I have added the condition "This device's value has changed within the last..."
    Hey Spud, are these going to be released as betas on the plugin update page soon?
    HS3 3.0.0.423 & HSTouch 3.0.55 with 700 Devices, 358 Events
    Plugin's:
    BLBackup, BLOccupied, BLShutdown, EasyTrigger, Ecobee,
    weatherXML, Jon00 Alexa Helper, Network Monitor, Z-Wave 3.0.1.206
    Plugin's:
    • group type
      Is it possible to have a "group type" option to the then drop down?
      • Originally posted by The Profit View Post
        Plugin's:
        +1 on this. I hate having to go in and manually copy the files over to my SEL.
          Plugin's:
          I've just submitted a request so that this version is released in the updater (not as a Beta, as changes are pretty safe). So, it should be in there soon.
          • Originally posted by Overst View Post
            Do you mean you want to be able to use the "Set Group of devices to Expression" action with groups based on devices name/location/type ?
            • oh yeah didn't think about that. I could see some applications in getting more specific but this would generally work.
                Yes exactly. So I could turn on all devices with "location 1" set to "living room" for example without having to set up a group with the name of each item.
                • Scrollbar on Device Group Window or ability to resize
                  An enhancement I'd like to see is adding scrollbars or window resizing to the add a Device Group. Currently, the window isn't large enough so it doesn't display the while name so I have to go to the HomeSeer. E.g. a device named "Upstairs Florida Room Back Door: Sensor" It only displays "Upstairs Florida Room Back Do" which doesn't allow me to pick the correct device. I need to go and shorten the names to see which is the correct one.
                  Even having a hover that displays the whole name would work.
                  Thanks!
                  • Originally posted by dnicosia View Post
                    Thanks!
                    To make the selector window larger, read this post: https://forums.homeseer.com/showthre...=191142&page=3
                    this fix is supposed to be in the latest HS3 release, I will check if it is.
                    • I've updated to HS3 .425 and it seems the same
                      • If NO device's value in this group has changed for exactly...
                        Hi Spud,
                        Is it possible to add another trigger ?
                        I want to monitor my 1-wire network : if no sensor has changed for exactly 2 hours, I restart Logtemp.
                        I've added all my 1-wire devices in a group.
                        It could prevent me to have a long list of "OR" in an event.
                        It could also be useful to restart a plugin if nothing changes for a long time.
                        I would like to have something like : "If NO device's value in this group has changed for exactly..."
                        Thanks for your help.
                        Yves
                        • I'd am working on an event and it might be a good addition to this plugin...
                          IF (EVENT NAME) has executed (X) Times within (Y TIME) then
                          For example, someone comes to cut the lawn on Thursdays... he drives over the driveways sensors over and over and we are bombarded with messages.
                          It would be great to say
                          *IF DRIVEWAY ALARM EVENT has executed 3 TIMES within 2 MINUTES then
                          and if today is thursday
                          Run temporary squelch event
                          where the trigger with the star is handled by the plugin...
                          Plug-Ins Enabled:
                          • Originally posted by wpiman View Post
                            @Spud, please chime in if I'm incorrect.
                            In my terminology what you describe is one type of a "Sequence".
                            Other very basic types of sequences would be like...
                            Event1 then Event2 then Event3 within N time
                            Device1 then Device2 then Device3 within N time
                            ... and such
                            Spud said these were not possible because of limitations in the HS3.
                            This is unfortunate as this was very easy to do in Vera using the $5 PLEG plugin. I used sequences in MANY events!
                            • Spud, would you kindly consider adding two additional triggers under 'a devices value is':
                              1) 'Increasing' if the new value set is higher than the prior value, at the time of a value change, this is true
                              2) 'Decreasing' if the new value is lower than the prior value, at the time of a value change, this is true
                              I use these in my existing system to fire some notification events on things such as the spa water temp is rising past 98 (triggers an announcement that the spa is ready, but doesn't trigger when dropping from 100 back down though 98 to cooler temps). I am migrating the logic over, and while I was tempted to right a quick PI to do this, I suspect it might be useful for others as well to be in a more well known common PI such as yours.
                              Best
                              Bill
                                With the current HS API I don't think a plugin can be notified when an event is executed, so this feature is not possible to implement.
