Easy Trigger plug-in - Feature Requests
This is a sticky topic.
  • Ltek
    in version 3.0.0.46 available here, I have added the condition "This device's value has changed within the last..."
    Nice.
    Any thought on the Global Variables being added to capture the qualifiers of the event, not just the trigger?
    Sent from my SM-G950U using Tapatalk
  • Ltek
    Is there a way for a plugin to extend the device to add a new database field?
    ...a user definable Device Category would help.
    ... built-in Device Types aren't standardized / consistent and not really usable for sorting or use in events
    To help fill the gap, I've been using:
    Composite Devices script I posted
    - creates dynamic (on-the-fly) device groups based on any combination of location fields, device name and device type
    Easy Trigger plugin
    - Device Groups (static) or a single device filter uses in events
  • spud
    Originally posted by kideon View Post
    Could you add the trigger for if a device has changed within the last xxx? I was planning on using this specifically for some occupancy scenarios like if the phone status changes to online and if the location has changed to near home within the last five minutes then change to home. Another scenario would be if motion is detected and the doors have changed status in the last xxx then xxx.
  • spud
    This is already there, there is a +/- field that you can use as an offset for the comparison trigger/condition
  • AgentGladstone
  • spud
    in version 3.0.0.45 available here I have added 4 global variables (ETDeviceRef, ETDeviceName, ETDeviceValue and ETDeviceStatus) which are set with the triggering device when a group triggers.
    This allows to do some things like the following:
  • sirmeili
    You can do it using a recurring trigger and the ET condiion "A device's value has Not changed for at least"
    Good idea. I've never used recurring triggers so didn't think to use it here Thanks for the heads up.
  • spud
    Originally posted by sirmeili View Post
    @spud, I see we have the option of "A device's value has NOT changed for exactly...". Can we get "A device's value has NOT changed for at least..."?
    I ask because I want to monitor a device to see if it has not changed in 24 hours. I also want to be notified on an hourly basis after that. If I use the trigger that's in there, I only get the first alert. If you can add the one for "at least", then I can set the event option "Cannot Re-run for XXXX" to 1 hour.
    Would this be simple to add?
  • sirmeili
  • kideon
    Would this allow us to piece together long messages? I’ve been working on my announcements and thinking of creative ways to do that dynamically without chained events.
  • bebaldin
    Yep that's a good idea, will do it.
    Excellent! I am really looking forward to seeing what I can do with this new feature.
  • kideon
    I could add conditions based on "last change date" like "last change date for device X is within Y minutes from now"
    That would be great! With that, rock solid occupancy detection will be in my reach. Would it be possible to include the potential values like door sensor changed to “open” within the last xxx minutes/hours/days/seconds?
  • spud
  • spud
    This is a good idea. Maybe the plug-in could create three global variables based on the triggering device when a group triggers: ETDeviceName, ETDeviceValue, ETDeviceStatus. Then replacement variables $$GLOBALVAR:ETDeviceName:, $$GLOBALVAR:ETDeviceValue: and $$GLOBALVAR:ETDeviceStatus: could be used in messages. This should be possible with a device group Trigger. A Condition would be problematic, since it is possible that more than one device in a group might be true for the Condition.
  • kideon
    This possible?
