Easy Trigger plug-in - Feature Requests
This is a sticky topic.
  • #16
    OK. I'm just going to keep my mouth shut from here on in.
    Originally posted by rprade
    • #17
      guys,
      if I implement it like this:
      the user choose x and y, let's say x=2 and y=10 in this example
      let's say t0 = 00:00
      the plugin draws a random number r1 between 2 and 10, r1=3 for example
      the event is triggered at t1=t0 + r1 = 00:03
      the plugin draws another random number r2 between 2 and 10, r2=5 for example
      the event is triggered at t2=t1 + r2 = 00:08
      etc...
      this way it's guaranteed that the event will be triggered at least once every 10 minutes, and no more than once in any 2 minutes period
      no need for w and z parameters, am I missing something?
      Any news on this front?
      • #18
        I have a little bit to add to the random request for you to think about. How about a condition so the event won't fire some times? Like a % maybe.
        AND IF 10% chance it won't fire
        Something like that.
        • #19
          yes I can add a condition that is randomly true X% of time, where X is configurable
          • #20
            You're like out fairy God........ father!
            • #21
              I would buy this plugin if it made randomizing several lights really easy based only on a virtual device or similar set to home or away and another set dusk to dawn!
              Jim
              Plugins:Z Wave 3.0.1.55, HS3 Pro 3.0.0.208, HS3Touch, HS3Touch IOS, Z-Net, SceneMaster, XBMC, Sonos, Media Controller, Envisalink (52 Virtual nodes), JowiHue, EasyTrigger, Liftmaster MyQ, BLBackup, BLLAN, BLRadar, Pushover
              Devices:Cooper RF9540, Cooper Scene, Yale Locks, Sonos, Phillips Hue and Lux, DSC, Somfy Blinds
              • #22
                in version 3.0.0.6 available here I have added random triggers and conditions as discussed in this thread.
                please test and let me know...
                • #23
                  Hi Spud,
                  Would it randomize things in an easier fashion than in this thread?
                  http://board.homeseer.com/showthread...37#post1179137
                  Jim
                  • #24
                    [ATTACH]46227[/ATTACH]
                    You rock
                    I'm going to add this to about 50 events right now.
                    • #25
                      Originally posted by 519zwave View Post
                      Hi Spud,
                      Spud may have a different answer, but I think this plug-in would work much better than any of the methods in that thread. Your lights will stay on for a fixed period of time, but the turn on times would be totally random.
                      Randy Prade
                      Aurora, CO
                      Prades.net
                      • #26
                        Thanks Randy - looks like I'll be giving it a try!
                        Jim
                        • #27
                          After I thought about it a little you could randomize the time it turns on and how long it stays on. Below are a pair of events that will
                          • Turn a light on at night at some random time from 0-5 hours, but not more often than once every two hours. The light has to have been off for at least an hour before it can come on again.
                          • Then it will turn off somewhere between 30-90 minutes after it is turned on.
                          • It will continue this process until sunrise.
                          So you can truly randomize both the on time as well as the duration of the light.
                          Randy Prade
                          Aurora, CO
                          Prades.net
                          • #28
                            This is outside the scope of this plug-in as they are actions.
                            I use a script to do this now but there have been a lot of requests. An action to increment or decrement a dimmer by X. This could also even apply to thermostat setpoints.
                            The action would be Then increase (decrease) Device Living Room lights by 10%
                            -or-
                            Then increase (decrease) Device Living Room Thermostat Heating setpoint by 1 degree
                            Another event action would be a toggle for binary devices - if the device is on, turn it off if it is off turn it on. Among other uses this could work with the random timer that S-F suggested to create random lighting events.
                            I threw this out there a few weeks ago. Am I correct in stating that this is outside the scope of this plug-in?
                            Randy Prade
                            Aurora, CO
                            Prades.net
                            • #29
                              -or-
                              I think this one may already be possible using the "Set Device to Variable" action. I have recently added the possibility to add or substract a constant to the variable. So you can do something like this
                              Set deviceX to $$DVR:<ref_X>: + 10
                              where ref_X is the reference id of the deviceX
                              see this thread for more information:
                              http://board.homeseer.com/showthread.php?t=174716
                              • #30
                                Yes, that works fine, I missed your having added the offset.
                                Randy Prade
                                Aurora, CO
                                Prades.net
