Originally posted by spud
View Post
Cheers,
Scott
Public Structure strEventData Public Event_Ref As Integer' The event reference ID number. Public Event_Name As String' The event name Public Event_Type As String' The event type, if used. Public GroupID As Integer' The event group reference ID number. Public GroupName As String' The event group name. Public UserNote As String' The user's note contents. Public Last_Triggered As Date' The time the event was last triggered or ' Date.MinValue if it has not been triggerd before. Public Retrigger_Delay As TimeSpan' If the event is prevented from triggering within a given amount of time, ' this timespan will contain that time period. Public Flag_Enabled As Boolean' True if the event is enabled for automatic triggering. Public Flag_Delete_After_Trigger As Boolean' True if the event is deleted from the system after it triggers. Public Flag_Do_Not_Log As Boolean' True if the event is set to not log information when it is triggered. Public Flag_Delayed_Event As Boolean' True if the event was created as a result of a delayed action or trigger. Public Flag_Include_in_Powerfail As Boolean' True if the event is to be included in powerfailure recovery. Public Flag_Security As Boolean' True if the event trigger(s) can be modified by a random amount ' when the security feature is enabled. Public Flag_Priority_Event As Boolean' True if the event is set to not have its execution queued. Public Action_Count' The number of actions in this event. Public Actions As String()' The list (array) of actions in action_type : action_name format. Public Trigger_Count As Integer' The total number of triggers and conditions in this event. Public Trigger_Group_Count As Integer' The number of trigger groups (If / Or If) in the event. Public Trigger_Groups As strEventTriggerGroupData()' The list (array of structure) of triggers in each trigger group. End Structure
