Easy Trigger plug-in - Feature Requests
This is a sticky topic.
    #61
    That is what i was thinking too but when i looked this morning i couldn't find them in the list (I have a ton of devices so it is hard to find things) so I figured you couldn't do it but I just looked again and found them under counters - timers :-)
    I wish someone would make an plugin to add a search bar at the top of the lists and device page
      #62
      Originally posted by spud View Post
      in version 3.0.0.17 available here I have added the following triggers:
      "This device's value has been in range [X,Y] for exactly..."
      "This device's value has NOT been in range [X,Y] for exactly..."
      Spud,
      These are great additions. Would it be possible to add the corresponding conditions?
      "This device's value has been in range [X,Y] for at least..."
      "This device's value has NOT been in range [X,Y] for at least..."
        #63
        Originally posted by teladog01 View Post
        Spud,
        I would love to, but unfortunately I don't think that's possible right now because there is no GetConditions function in the HS API. So, when you start the plugin it would not be able to know which devices it needs to track and for what range.
        I will ask if this function can be added to the HS API
          #64
          Ranges for trigger "This device's value was and becomes"
          Could you add ranges to the trigger "This device's value was and becomes"? For example, "Device X was in the range 1..5 and becomes in the range 6..10".
          Also, I noticed that if a device has range values, the trigger only lists the first value in the range. For example, the values listed for a dimming light are "On Last Level", "On", "Off", and "Dim 1%". The other dim values are missing. Is this a bug?
            #65
            Ah, fair enough. Thanks for looking into it.
              #66
              Originally posted by matthewb View Post
              I would like to see a three Triggers for
              1. The devices Status does not change for a period of time" then a selector for days/hours/minutes/seconds.
              2. The devices Value does not change for a period of time" then a selector for days/hours/minutes/seconds.
              3. The devices String does not change for a period of time" then a selector for days/hours/minutes/seconds.
              It seems this would make adding watchdog/heartbeat checks much easier to accomplish.
              in version 3.0.0.18, available here
              I have added the trigger "This device's value has NOT changed for exactly..."
                #67
                yeah it's bug, I will add the possibility to enter ranges and fix the bug
                  #68
                  I have a specific need for dimmable devices that could be helped by setting to a device or variable +/- a percentage.
                  I have some LED strips controlled by PWM and because each LED color produces a different output luminance at a given pulse width, to create White, blue needs to be about 20% down and green about 13% down from red. I would like to make a master level virtual device, so that I could raise and lower the dim level of the LEDs and maintain a similar color balance. +
                  This also would allow a virtual device to control the relative dim level of a number of devices, always keeping the same level relationship to one another.
                  HS4 Pro, 4.2.18.9 Windows 10 pro, Supermicro LP Xeon
                    #69
                    I don't think this is currently in there, but I would like to request a new condition: A devices value has changed to X in the last X time span. This is similar to the Trigger "A devices value has been [value] for at least/exactly [timespan], however it checks if it has been a value for less than a specified amount of time instead of if it has been longer.
                    For example:
                    Trigger: The Garage door was closed
                    Condition: The Garage Lights were changed to On (value) in the last 5 minutes (time span).
                    It could also be written:
                    Condition: The Garage Lights has been On (value) for no more than 5 minutes (time span).
                    Frank
                    MeiAutomtion Home
                      #70
                      What about a condition for if a device value has changed and is increasing / decreasing by +/- x?
                      I was thinking of using this with my temperature monitoring of my freezer's and refrigerator's.
                      I have been trying to figure out a way to easier way to check for "temperature is greater than x... and is increasing or decreasing" so I know how concerned I should be.
                      Len
                        #71
                        For example:
                        Frank
                        This one is not possible to implement because AFAIK there is no way to get a list of all the conditions from the HS3 API, so the plugin can't know what devices to monitor.
                          #72
                          Why do you need a list of all the conditions? (serious question). So you already have a condition called "Easy Trigger: A Devices Value is...". Then in the next dropdown you have a list of options (Well 1 option). Could you not have an option that says "This devices has been/For at most..."? Then all the plugin has to do is check if the value is correct and do a date/time span on the last time the value changed.
                          Understand, that it may be one of those times where doing something seems really easy, but in actually it's really hard (as a developer, I do understand this). I'm just wanting to make sure you understand the request.
                          MeiAutomtion Home
                            #73
                            To know the last time the value changed, I have to monitor the device for changes. So the plugin needs to know which devices to monitor when you start the plugin, thus the plugin needs to retrieve all the conditions at startup.
                              #74
                              Instead of adding specific operation like this one, I think I'm going to add a "Set Device to Expression" where you can use simple mathematical operations with global variables like for example:
                              $$DVR:123: + $$DVR:345: * 2 / 100
                                #75
                                Perfect! And flexible.
