Easy Trigger plug-in - Feature Requests
This is a sticky topic.
    Hi Spud
    I wanted to request a feature for triggers, for your consideration?
    Before Sunset +/- ? hour
    After Sunset +/- ? hour
    Before Sunrise +/- ? hour
    After Sunrise +/- ? hour
    Between Sunrise +/- ? hour to Sunset +/- ? hour
    Between Sunset +/- ? hour to Sunrise +/- ? hour
    Post Ref: http://board.homeseer.com/showthread...=1#post1260428
    I am going to attempt to do this on a schedule, but do think this may be a nice feature to have. This is another great plugin of yours.
    Keep up the hard work
      Originally posted by smokeycoles View Post
      Hi Spud
      I think you want conditions. The first four are already HS triggers. The first four would work best as ranges rather than specific times. For example:
      The time is after 30 minutes before sunrise
      -or-
      The Time is before 30 minutes after sunset
        Randy you are indeed correct. Sorry Conditions is what I would like please.
        I always confuse them!
        And I agree about the first 4.
          Another request please to consider:
          Toggle Events
          For Example, Application:
          Event1: Open All Blinds Fully
          Event2: Open All Blinds (Comfort)
          Event3: Close All Blinds
          Thank you
            in version 3.0.0.29 available here
            I have added 4 time conditions:
            • The time is before (sunrise +/- T)
            • The time is after (sunrise +/- T)
            • The time is before (sunset +/- T)
            • The time is after (sunset +/- T)
              Thanks, works great! I've gotten accustomed to using schedules, but this is a nice option to have.
                Suggestion for an advanced timer
                Hi Spud,
                i was thinking something , would it not be nice to add a advanced timer to this plugin ?
                so we can trigger also trough script and maybe other options ?
                Because the one what is build in homeseer doesnt work with scripting..
                I think many people would like it ,
                How u think about it ?
                Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
                HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
                  Random wait?
                  Originally posted by stefxx View Post
                  So instead of a "Then Wait 2 Minuten, 20 Seconds" something like "Then Wait between 2 minutes, 10 Seconds and 5 Minutes, 30 Seconds"?
                  Hi Spud,
                  Never got a response on this request. Is this something you want to consider?
                  Thanks again!
                  stefxx
                    [ATTACH]56106[/ATTACH]
                    Great! Two questions:
                    - It doesn't seem to work for group actions (time is always reset to 0). Is this a bug of by design?
                    - What about Between Sunrise +/- ? hour to Sunset +/- ? hour? I tried to combine the conditions to make a "between" condition but it doesn't seem to work (before sunrise +/- and after sunset +/-, one is always false )
                    stefxx
                      Hi Spud,
                      Thanks again!
                      The HS3 API limits to 2 minutes the delay for a plugin action to respond, so if I would implement a "random wait" action it would be limited to 2 minutes, so I think this is one feature that must be implemented in HS3 itself.
                        Makes sense. Thanks!
                        stefxx
                          - group conditions are buggy when the conditions comes from a plugin. I have reported it several times, but no luck so far.
                          - "before sunrise AND after sunset" can never be true because the current date-time is compared to sunrise/sunset time of the current day.
                            Exactly! That is why I was requesting a "Between sunset +/- time and sunrise +/- time" condition
                            There is a standard condition "If the time is nighttime (after sunset, before sunrise)" but I can't do a +/- time on the sunset/sunrise unfortunately.
                            stefxx
                              You would duplicate your triggers (using Easy Trigger Conditions) to make it work.
                              IF Trigger
                              AND IF The time is after (sunset +/- T)
                              OR IF Trigger
                              AND IF The time is before (sunrise +/- T)
                              Then Action(s)
                                Thanks. That is why I hate "OR IF", because you have to duplicate all the other triggers/conditions as well. It gets messy quickly.
                                stefxx
