Easy Trigger plug-in - Feature Requests
This is a sticky topic.
I'm not sure it's possible but I'd love if there was an event trigger for when homeseer or an addon update was available
Originally posted by spud View PostFilter mechanism is not exposed through the API, so I don't think there is an easy way to do this.
Ok, thanks Spud.
Originally posted by The Profit View PostHi Spud,
I have been using Easy trigger time ranges for a little while and they are extremely helpful. Do you know if there might be a way to filter events based on a specific easy trigger schedule? Similar to filtering events based a a specific device used in an event?
Thank you Spud
Thank you Spud
Bump
Hi Spud,
Thank you Spud
Originally posted by Ltek View PostTo limit repeats, using "Cannot re-Run For" option works well IMO.
alternatively you can use the condition "value has NOT changed for at least" which also already exist in EasyTrigger.
Originally posted by spud View PostI'm not sure I can get the "Last run time" field either...
Originally posted by spud View Posthaving a "at least" trigger would not make much sense as it would fire the event every second once it is true.
'has been for at least' (requires specific value)
'has been for exactly' (requires specific value)
... but not...
'value changed within last <time>' (good for ANY value)
'string changed within last <time>' (good for ANY value)
'value not changed for at least <time>' (good for ANY string)
'string not changed for at least <time>' (good for ANY string)
many use cases for constant alerts, like...
Fridge/freezer - Saving your food from spoiling or wasting a ton of energy
Door open - saves dog from running out and getting hit by a car
Water leak - house flooding
Originally posted by Ltek View PostFor the Event Sequences, I was thinking it would not be immediate but based on 'Last Run Time'. Comparing current time with last run time.
Event 'Last Run Time' changed within the last 5 seconds.
Originally posted by Ltek View PostFor "This device value has not changed for exactly" .. does it really mean 'exactly' (exactly 22:30 -- but not 22:29 or 22:31) or is it really 'at least' (22:30 or longer ... aka >=) situation?
I was hoping to have triggers like...
Device Value has not change within the last 30 min.
Device Value changed within the last 20 minutes
a trigger: "This device value has not changed for exactly.."
and a condition: "This device value has not changed for at least..."
Originally posted by spud View PostFor the first one, I could not find in the HS API a way to be notified when an event is fired.
For the second one there is already an EasyTrigger called "This device value has not changed for exactly..."
When
Originally posted by andyf View PostAll my Z-Wave battery nodes report a capacity in %. It is possible for a battery to skip % values between reports so having to trigger on an absolute value is somewhat limiting. It would be nice if you could add a "greater than" and "less than" to this new trigger.
Originally posted by Ltek View PostNICE!
Interested in your thoughts on triggers for...
Event did/not run within the last XXX seconds/min/hr
Device value changed/not within the last XXX seconds/min/hr
... these would allow us to do basic Event sequences.
Originally posted by spud View Postin version 3.0.0.35 available from the Beta section of the updater I have added "Any Device's value in Group is..." triggers and conditions.
The group can be based on Name, Location1, Location2 or Type
This allows you to simplify long list of OR IF triggers.
example: "Any device whose type is XXXX had its value changed and becomes Y"
[ATTACH]62893[/ATTACH]
@spud
another, hopefully easy (?) request...
If <event name> has ran within the last <#> seconds/minutes/hours
If <event name> has NOT ran within the last <#> seconds/minutes/hours
I found several instances (a few different use cases) where it would be valuable to check an Event's Last Ran time and use it as a Condition to stop, or allow, another event from running.
It would also provide users with very basic event sequences.
Possible? thx for the help!
