Easy Trigger plug-in - Feature Requests
This is a sticky topic.
  • spud
    in version 3.0.0.34 available from the Beta section of the updater I have added 3 device's value conditions:
    • This device's value has been in range [X,Y] for at least...
    • This device's value has NOT been in range [X,Y] for at least...
    • This device's value has NOT changed for at least...
  • spud
    Originally posted by Ltek View Post
    <event> was just ran
    This Event was triggered by <event>
    ... good for basic sequences
    <event> was last triggered manually/directly
    ... good to determine if it was automation logic, or human intervention. For instance, if it was human intervention, you may want to leave the lights on, not
    I don't think I can add those because the information on how the event has been triggered is not available from a plugin.
    Device value is set and NOT Equal to <value> for at least <time>
    We already discussed adding the "NOT Equal to <value> for at least <time>" condition a while ago, but it's very difficult to implement because there isn't any function in the API to get all the conditions, so the plugin don't know which device value to monitor.
    Device value Just changed based on; <keyword> and/or Location and/or Name
    I think I could add this one
    Time is NOT <between or after or before>
    I think you can already do these ones with some boolean logic
    Time is NOT after = Time is before
  • spud
    Originally posted by andyf View Post
    Yes, that's the one. Same reason, a Wait hangs up the thread rather than just scheduling a future device action and continuing. I did read in one of the how to's or clinics that it really wasn't recommended to use Wait.
    It may be a plug-in doesn't have access to this but if it does I would really like to see this implemented.
    This is a really great general use must have plug-in. Every couple of days I find events in my system that I realize I can make much simpler using an EasyTrigger feature.
    got it, but unfortunately I don't think I can create delayed event action using the HS API.
  • Ltek
    Thoughts?
    Spud,
    Would you be able to add these:
    example use cases:
    a. Trigger an event based on anything happening within a room or location, with 1 single IF... instead of multiples
    b. Currently I trigger a script and the event requires over 20 IFs where all devices the same <keyword> in the Name (Window)... if you add this to Easy Trigger, I would be able to replace 20 IFs with 1 IF.
    Similarly, there are many cases where the negative (NOT IF) is needed. Can you add new 'qualifiers'?
    We need qualifiers that allow EXCEPTIONS (aka NOT IF) - in some cases without Exceptions in the event, some things are just not possible in the Event engine and when a work-around is possible it requires logic to be verbose and tedious, and in many cases redundant across multiple events
    The below would Massively enhance the capabilities, IMO
    NOT IF <event> was last triggered manually, not from an event
    NOT IF <vDevice> was last triggered manually, not from an event
    ... currently a painful and only partial workaround is to create a separate Event which the first Event calls, where the 2nd Event includes exceptions in the form of more Conditions that further narrow the scope of the IF's. Completely inadequate and does not cover most situations that a NOT IF would easily handle within a single Event.
  • randy
    Are you talking about the "After Waiting X days Y hours..." option there is at the bottom of the "Control Device" action?
    If so, is there any difference between this option and adding a wait action before the control device action?
    To elaborate on what Nicolas said, a delayed device action allows an event to complete, placing a new event in a Delayed Actions queue with a time trigger. Even if you have dozens of delayed actions the primary event completes spinning off new self-deleting events for delayed actions and events. A "Wait" simply pauses an event each time a Wait is called. While you can cancel an event while it is in a Wait action, you have no way of knowing where in the event processing is if there is more than one wait.
    A delayed device action is always preferable to a Wait.
