Originally posted by mterry63
View Post
Easy Trigger plug-in - Feature Requests
This is a sticky topic.
Originally posted by rge View Post
Isn't that the same as using the "This Device Has a Value that Just Changed" event, plus possibly the "Event cannot re-run" option.
An easy workaround is to trigger every x seconds and test hs.DeviceTime() > y. Would be nice to check DeviceTime in EasyTrigger though.
This might be possible already - I can't see it. A condition based on the time that an event was run (e.g. event run less than an hour ago etc). Currently if a change is made from outside of HS I would want a future event to happen depending on whether an event had run or not. In my case, it's electric Velux Windows which can be opened or closed either by the Velux remote OR by an HS event. Currently I use a virtual device as a variable set by an associated event.
Scott
Originally posted by mterry63 View Postspud Would it be possible to add using HomeSeer functions in an expression for "This device had it's value set and expression is true"? For example hs.DeviceTime(124) > 15? Or alternatively, add an easytrigger function that checkes if the DeviceTime() value is greater than some number instead of "Device Value has not changed for x". I have several devices that don't regularly change for long periods, but they are being updated by HS3 regularly. This caused the the "Device Value has not changed" to be less useful.
Originally posted by Join View Post
Yeah, that would do it. It can fluctuate 1-2degrees.
But, how to apply the data? Is it: "If this mathematical expression is true:"?
I don't know how to atm..
$$DVR:101: * 0.9 + $$DVR:100: * 0.1
If you want to do switching with a gap, use the same option on the switched device and an if statement in the expression. Let's say the switch is ID 102:
IF($$DVR:101: < 20.0, 1, IF($$DVR:101: > 20.5, 0, $$DVR:102)
This is: if V < 20.0 set switch to 1 else if V > 20.5 set switch to 0 else set switch to the value it already has (i.e. do nothing). Also use the option to only set the value if it changes.
The way I handle noisy temperature measurements is to have two thresholds with a small gap. For example:
- turn heating on if temperature < 20.0C
- turn heating off if temperature > 20.5C
So if it's fluctuating a bit it doesn't keep turning the heating on and off.
For even more noisy measurements such as sun brightness I take a moving (exponentially weighted) average - create a virtual device for the "average measurement" and then an event to run every so often (e.g. every one or two or five minutes) which gets the raw measurement and sets the virtual device to:
V = V * e + R * (1 - e)
Where V is the virtual device value, R is the raw device value, and e is the exponent - something like 0.9 gives a fairly slow response, 0.5 is a simple average of the two values and responds much quicker (obviously also dependent on how often you check).
Originally posted by Join View PostHi!
I wish there was a way to compare two devices, if the condition are true for X-time. Added screenshot:
OR, is there another way I have not figured out?
The reason is, the air/air heater got an internal temperature sensor, but it is only read whole degrees, and it's output is a bit irregular, so it is not easy to use it for conditions and get a stable output.
BUT, its powered(KNX-device), and put out a lot more readings than the battery operated multisensor.
If there's a way to say: IF this is true for 10minutes, THEN..
Just my 2cents.
Thanks for a great plugin!
- Likes 1
Just my 2cents.
Event1 If comparison is true Then set virtual device ON
Event 2 If comparison is not true Then set virtual device OFF
Event3 If virtual device has been ON for [time] Then execute action
Depending on your needs, a second action on Event3 could set the virtual device back to OFF.
- Likes 1
Hi!
Just my 2cents.
I would add a voice to the 3 other advocates of adding HS4 category support. Even just static groups would be fine. Though I don't think there is any notification when members of a category change, so you might have to add some manual update to your UI and a plug-in call. Just wildly guessing. In any case, it would make categories a lot more useful.
Originally posted by rge View PostAnother nice time feature would be to specify "earlier of" or "later of", so sunrise and sunset can be used but with a limit. e.g. I want to open my blinds 15 minutes after sunrise, but not before 06:30, and close them at sunset but not later than 21:00.
It could be specified using > and < for example:
>06:30,sunrise+00:15 = later of 06:30 and sunrise+15m
<21:00,sunset = earlier of 21:00 and sunset
But it would need to allow composed schedules to be composed further, to cope with both earlier/later and start/end conditions. On the bright side, it would only change when sunrise and sunset change, same as with the other schedules.
- Likes 1
- Likes 1
Guest repliedOriginally posted by ZoRaC View Post
Moskus has made a solution for this.
It’s written in Norwegian, but the screenshots and Google translate should make it understandable:
https://www.hjemmeautomasjon.no/foru...#comment-63553
Originally posted by adamgreenberg View PostWould be great to be able to compare the actual time (in a virtual device that updates every minute) vs. a virtual device that has a time set to trigger an event. The specific use case is as an alarm in the morning. Some days, I want the lights to come on at 7:30 and some days 8:00. I'd set a regular schedule (e.g., weekday vs. weekend) and then some events that would enable me to turn off the alarm for a day or until turned back on, ability to easily change the time of the alarm etc... The missing piece that I can't get to work is the comparison of the time in two virtual devices. I've seen so many posts about people wanting to create an alarm function.
- Likes 1
