New Devices
    New Devices
    Is there a delay between when a device is added to HomeSeer and when it shows up in the list of devices I can use with Easy Trigger? I added a couple new Aeotec Micro Dimmers to HomeSeer and they work fine, but when I go to add them to an existing event, they don't show in the list of "Easy Trigger: Set a Device to Variable" devices.
    It's ok if there's a delay, I just want to know if I'm missing something. And how long the delay is, if it's on purpose.
    Thanks!
    I'll let Spud answer this with authority, but in the log it looks like the plug-in builds a device list for triggers on startup, so I would recommend restarting HomeSeer.
    HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
      the plugin build the list of available devices when it starts and is supposed to add to this list when a new device is created. However I just tested it and it does not seem to work, I will have a deeper look at this problem. The workaround is to restart the plugin so that the device list is rebuilt from scratch (no need to restart HS3)
        Perfect. Thanks!
