assuming 4083 is the correct event then the problem may be the "AND IF" condition, can you try to remove it to test?
when you see "Firing Event ###" in EasyTrigger log it means Easy trigger has found a trigger that needs to be run, but then the HS3 engine still needs to evaluate the conditions before the event is actually run
