string changes and contains
    Hi Spud, sorry if this was answered already, I checked the doc but could not find the answer. Can I specify multiple strings to check against the device string? Should they be separated with a delimiter such as comma?
    -Ron
    no sorry you can't specify multiple strings, you will have to use several triggers (OR IF)
      Hi Spud. Can 'If String Contains' field handle regular expressions?
        In version 3.0.0.52 available in Beta section of the updater I have added "String changes and matches this regular expression" trigger and condition.
        Here is an example that check if a device string is an email address:
          That is brilliant. Cheers Spud
