problems with the plugin after restarting
  • problems with the plugin after restarting
    hi Spud
    After restarting nd updating my homeseer , easytrigger doesnt work anymore ..
    it starts up fine , but events with a time range won't trigger anymore
    before it worked..
    Event is like this :
    IF pir is person detected
    AND IF Pir is in daytimepir time range THEN
    Speak test
    this is the log after restart :
    Aug-15 13:09:17	 	Plug-In	Finished initializing plug-in EasyTrigger
    Aug-15 13:09:17	 	EasyTrigger	INFO Found 0 random triggers
    Aug-15 13:09:17	 	EasyTrigger	INFO Refreshing list of random triggers to monitor
    Aug-15 13:09:17	 	EasyTrigger	INFO Found 3 schedule triggers
    Aug-15 13:09:17	 	EasyTrigger	INFO Refreshing list of schedule triggers to monitor
    Aug-15 13:09:17	 	EasyTrigger	INFO Found 0 device's value triggers
    Aug-15 13:09:17	 	EasyTrigger	INFO Refreshing list of device's value triggers to monitor
    Aug-15 13:09:17	 	EasyTrigger	INFO Found 7 device's string triggers
    Aug-15 13:09:17	 	EasyTrigger	INFO Refreshing list of device's string triggers to monitor
    Aug-15 13:09:17	 	EasyTrigger	INFO EasyTrigger version 3.0.0.27
    Aug-15 13:09:17	 	Info	Plugin EasyTrigger has connected. IP:127.0.0.1:18019
    Aug-15 13:09:03	 	Info	Plugin EasyTrigger with instance: has disconnected
    Aug-15 13:09:03	 	Plug-In	Shutting down Plug-In: EasyTrigger
    regards
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    weird it works again ,
    the only thing i did is restart the plugin again...
    i also did yesterday 3 x
      Hi spud again i have this strange issue , Here are Some screens.
      Before the restart iT works normal , now o restarted homeseer and i get all these warnings
      Verzonden vanaf mijn iPhone met Tapatalk
        Those errors usually mean that you created Easy Trigger triggers, then deleted the devices. If you expand the events in the log above, you will probably see that the event is broken. Either edit them to have an existing device or delete the event.
        Randy Prade
        Aurora, CO
        Prades.net
          hi randy
          The events are not broken , still there and i didn't touch them , the devices are also there , i didn't delete them
          the whole plugin doesnt trigger anymore all the events don't work...
          this is one of the events and its untouched ,
          regards
            i restarted easytrigger 7x after that i put it to debug and bacl again and now the errors are gone , and its working again .
            but after a homeseer restart i get this error's .
            Spud can you fix it , because sometimes my homeseer server makes an backup and restarts homeseer..
            regards
              regards
              I would love to fix it, but I would need to know what the problem is.
              What your logs say is that at some point HS is unable to talk to the EasyTrigger plugin but it doesn't say why.
              First, could you set the log level to Debug and recapture the problem when HS restart and post the entire log.
                i spud
                i already had it on debug , but i got only this
                but after put it back from debug to normal log and i restarted , it works again.. but it happens everytime i restart homeseer..
                the plugin works only the time schedule not .. and it even shows me a schedule what i had deleted a very long time ago..
                  i spud
                  this logs show that HS (or maybe another plugin) is trying to evaluate triggers before that the EasyTrigger plugin is even started, which is obviously wrong. Do you have some particular scripts that are run at startup? What other plugins are you running? Try to disable them and see if you still have the problem.
                  I would need a more complete log to tell more, one that shows the complete startup of HS, plugins, etc..., you should see at least something like that at startup:
                  Regarding the deleted schedule: every schedule is saved in Config/EasyTrigger.ini, so look at this file to see if it's there?
                    i did a manual restart and it works normal..
                    so it is the event.
                    after the backup it starts homeseer like this .
                    my backup is a bat file , it wil create a zip file with the name date and time and specific folder
                    "C:\Program Files (x86)\HomeSeer HS3\HS3.lnk"
                    it is run as administrator ofcourse
                    so i think your plugin is having problems with it ...
                      Hi Spud,
                      Today i used jon00 restarthomeseer.exe and also with that one iT doesnt trigger Any time based triggers anymore..
                      No errors at all this time .
                      Regards
                        Hi Spud,
                        Regards
                        I can't help you if you do not provide more information especially for a problem that I can't replicate and that you are the only one to report.
                        So please post a full debug log of the restart.
                          Hi SPud ,
                          here the startup log from homeseer , + the debug log from Easytrigger
                          Like i said before , its not a plugin issue .. it only happens when i start homeseer from an other exe file like the one from Restart plugin , or the one from jon00 , or a bat file containing the path to homeseer.LNK
                          because of that only the time events don't work from easytrigger the rest works normal from easytrigger
                          If i do start it normal it works like it should
                          regards
