Plugin Errors
  • Plugin Errors
    Is there a Newtonsoft.Json file in your HomeSeer directory?
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
      Thanks, Rien
      I'll look tomorrow.
      Fischi
        Hi Rien,
        there is a Newtonsoft.json.dll v.4.5.11.15520 under JsonConfigForHomeKit
        AND
        a Newtonsoft.json.dll v. 8.0.2.19309 under HomekitBridge.
        Is there an issue ?
        Fischi
          So these 2 are the only 2 Newtonsoft.json.dll files on your Win7 PC
          It looks like a Newtonsoft.json.dll conflict though
          Can you also check if you have an HSPI_JSONCONFIGFORHOMEKIT.exe.config in the HomeSeer root folder?
          Rien du Pre
          The Netherlands
          Using:
          Plugin's:
            Thanks Rien,
            I will look into my HS root folder if there is the exe.config .
            Is it possible that the Newtonsoft.dll is a "fragment" from Fraggel's
            HS3 Homekit plugin ?
            I've deleted this plugin because it doesn't run and it's very unstable.
            Best regards,
            Fischi
              Rien,
              I have a HSPI_JSONCONFIGFORHOMEKIT.exe and a
              HSPI_JSONCONFIGFORHOMEKIT.exe.config in my HS root.
              I've also found a (third) Newtonsoft.Json.dll / Json.Net. Portable .Net 4.0 v.6.0.6.17820 in my HS root that I han't realized !
              Hope we will find tge error(s).
              Fischi
                Please delete that dll and try again, maybe you have to reboot
                Rien du Pre
                The Netherlands
                Using:
                Plugin's:
                  Thank you very much Rien,
                  It seems to run OK now.
                  I can see the JsonConfigForHomekit tab and i's very convenient now to add devices to HOME/SIRI.
                  I didn't have to restart HS.
                  Best regards,
                  Fischi
                    After deleting this Newtonsoft:Json.dll the plugin is working OK.
                    But there came another issue:
                    I can't go to my z-wave device settings anymore !
                    I've restored the Newtonsoft.Json.dll into HS root again and the
                    settings of my z-wave devices are running OK again, but the JsonConfig
                    for Homekit doesn't run anymore !
                    How to solve this issue ?
                    Fischi
                      After numerous tests and numerous research I believe finally to have found the problem of stopping the homebridge! It comes into conflict with teamviewer! And the HSSentry! Deactivate the 2 and you will see that the homebridge no longer stops! I have to install ultravnc and it does not give any problem! Thank you for making me follow your test!</pre>
