Remote KMS client crashes on W10
  • Remote KMS client crashes on W10
    Hi spud,
    I've had a few crashes of a remote instance on a W10 device:
    - System
      - Provider
       [ Name]  .NET Runtime
      - EventID 1026
       [ Qualifiers]  0
       Level 2
       Task 0
       Keywords 0x80000000000000
      - TimeCreated
       [ SystemTime]  2016-03-19T20:10:17.000000000Z
       EventRecordID 7672
       Channel Application
       Computer Spengler
       Security
    - EventData
       Application: HSPI_KMS.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.NullReferenceException Stack: at System.Runtime.Remoting.Messaging.LogicalCallContext.PropagateIncomingHeadersToCallContext(System.Runtime.Remoting.Messaging.IMessage) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(System.Runtime.Remoting.Proxies.MessageData ByRef, Int32) at HomeSeerAPI.IHSApplication.WriteLog(System.String, System.String) at HSPI_KMS.Logger.Log(System.String, ELogLevel) at HSPI_KMS.KMSApp.OnSensorStatusReport(System.Object, System.EventArgs) at HSPI_KMS.Sensor.UserInputReceived() at HSPI_KMS.Sensor.MouseMoved(System.Object, MouseKeyboardActivityMonitor.MouseEventExtArgs) at MouseKeyboardActivityMonitor.MouseHookListener.InvokeMouseEventHandlerExt(System.EventHandler`1<MouseKeyboardActivityMonitor.MouseEventExtArgs>, MouseKeyboardActivityMonitor.MouseEventExtArgs) at MouseKeyboardActivityMonitor.MouseHookListener.ProcessMouseMove(MouseKeyboardActivityMonitor.MouseEventExtArgs ByRef) at MouseKeyboardActivityMonitor.MouseHookListener.ProcessCallback(Int32, IntPtr) at MouseKeyboardActivityMonitor.BaseHookListener.HookCallback(Int32, Int32, IntPtr) at System.Windows.Forms.UnsafeNativeMethods.PeekMessage(MSG ByRef, System.Runtime.InteropServices.HandleRef, Int32, Int32, Int32) at System.Windows.Forms.Application+ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr, Int32, Int32) at System.Windows.Forms.Application+ThreadContext.RunMessageLoopInner(Int32, System.Windows.Forms.ApplicationContext) at System.Windows.Forms.Application+ThreadContext.RunMessageLoop(Int32, System.Windows.Forms.ApplicationContext) at HSPI_KMS.KMSApp.RunHookThread() at System.Threading.ThreadHelper.ThreadStart_Context(System.Object) at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object) at System.Threading.ThreadHelper.ThreadStart()
    Any ideas?
    Al
    HS 3.0.0.548: 1976 Devices 1156 Events
    Z-Wave 3.0.1.262: 123 Nodes on one Z-Net
    This mostly seems to happen when the w10 system comes ot of sleep/suspend mode.
    Cheers
    Al
      This kind of exception is usually raised when the plugin can't communicate with HS, but I don't understand why it makes the plugin crash, it should only log an error.
      I will try to reproduce and debug it.
        Thanks!
          I'm not getting W10 crashes but sometime in the last couple of weeks (aka a W10 update I'm sure) all of a sudden the mouse control goes bonkers. I disable KMS and it runs fine.
          More than happy to help you troubleshoot if you want to tell me what to monitor or look for.
          Ken J.
            I'm getting the same thing ... what's the solution
            I cannot find a pattern but every couple of days KSM crashes on Windows 10 Pro. I've tried running it in both "console" mode and not. This is a remote instance and it not the machine with HS. I have version 3.0.0.5.
            It's not usable if I can't rely on it of course. It turns my monitor on among other things.
            I have another problem which I will post separately.
            Tahl
              Tahl
              check my answer in the other thread.
