Plugin issues with HS3 3.0.0.478
    #16
    Make sure you have a fresh backup... I didn't...oh well...
      #17
      If your system got messed up, shut down HS and copy over one of the backup HSD files to the main HSD file (the _# ones) and delete the file Z-Wave2.db in the Data folder. Then start HS. All should be as it was.
        #18
        Well, I don't recall this happening before.
        Jan-25 3:43:59 PM Z-Wave Warning A Z-Wave action in the event Locks Poll back door lock returned an incomplete (failed) result.
        Jan-25 3:43:59 PM Z-Wave Error Event Action Error: Event Locks Poll back door lock cannot POLL NODE because the device specified to be polled is not a Z-Wave parent or child device.
        Last edited by joegr; January 25, 2019, 04:54 PM. Reason: Okay. Looks like everything Z-wave has stopped working. I do have a backup to restore from when I get home...
          #19
          I had the same issue of things going dead. I did a Scan existing devices (light) and things started working again.
            #20
            New issues...
            After spending the day in between normal work and excluding devices I'm again excluding some devices just for testing and using the latest z-wave plugin .255 and on each EXCLUDE well it excludes... then it SCAN and CREATES NEW devices..... Something is seriously wrong with the z-wave plugin.
              #21
              I did this, but things still weren't working correctly.
              After doing this too, it seems to be okay.
                #22
                New issues...
                Have you tested to see if it is safe to revert to 3.0.1.252?
                  #23
                  If the damage is done you also have to restore the HS database otherwise the devices are still messed up.
                    #24
                    Yes, as I said I did that, and I have it working now. I am just concerned about keeping it working. If I go back to version 252, will that cause any problems?
                      #25
                      You would have to ask HST if there would be any problems. Like I said before I didn't have a good recent backup... I'm bad about that because my system is in flux constantly anyways.
