Life360 throwing UpdateInterval Exception
    sirmeili
    Hi Frank, today i started getting these errors in my HS3 log every minute. A restart of the plugin seems to have fixed it for the moment, but wanted to let you know in case you get a chance to check it out when you are looking at the code.
    Feb-01 4:09:57 PM Life360 ERROR Exception UpdateInterval: Newtonsoft.Json.JsonReaderException: Unexpected character encountered while parsing value: <. Path '', line 0, position 0. at Newtonsoft.Json.JsonTextReader.ParseValue() at Newtonsoft.Json.JsonTextReader.Read() at Newtonsoft.Json.JsonReader.ReadForType(JsonContract contract, Boolean hasConverter) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.D eserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent) at Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReade r reader, Type objectType) at Newtonsoft.Json.JsonConvert.DeserializeObject(String value, Type type, JsonSerializerSettings settings) at Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value, JsonSerializerSettings settings) at Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value) at HSPI_Life360.Plugin.UpdateLife360Devices(Object obj)
    Nothing else in my system seems to be having issues at the moment, and after restarting the plugin it seems to be working ok. I will let you know if the error returns. Thanks.
    -mda
    System info:
    Current Date/Time: 2/1/2020 4:15:57 PM
    System Uptime: 20 Days 22 Hours 34 Minutes 29 Seconds
    IP Address: 192.168.1.141
    Number of Devices: 942
    Number of Events: 687
    Available Threads: 400
    HSTouch Enabled: True
    Event Threads: 3
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    In Virtual Machine: No MFG: lenovo
    Enabled Plug-Ins
    3.0.0.32: Autelis
    2.0.61.0: BLBackup
    3.0.49.0: BLGData
    2.0.28.0: BLOccupied
    1.0.5.0: BLShutdown
    1.4.0.4: Device History
    3.0.0.70: EasyTrigger
    3.0.0.33: Ecobee
    5.0.0.58: Global Cache Pro
    3.0.0.325: Life360
    3.1.0.17: MeiHarmonyHub
    3.0.1.0: MyHSToken
    1.2019.1126.1081: MyQ
    3.0.0.14: NetCAM
    3.0.0.48: PHLocation2
    0.0.0.47: Pushover 3P
    1.0.0.7: Restart
    30.0.0.37: RFXCOM
    3.0.7.6: SDJ-Health
    3.1.0.51: Sonos
    1.4.1.0: Tesla Vehicles
    3.0.7272.26248: UltraLighting3
    3.0.1.0: Vista Alarm
    3.0.0.23: WeatherFlow
    3.0.1.19: weatherXML
    1.2.0.1: Zodiac Iaqualink
    3.0.1.262: Z-Wave
    Ok. I will take a look. I may need to add some debugging and pass you an alternate version to try so I can get where the error is happening.
      Thanks!
      Today I am getting this error approximately every 5 hours so far (and once yesterday):
      Feb-03 10:02:23 AM Life360 ERROR Exception UpdateInterval: System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_Life360.Plugin.UpdateLife360Devices(Object obj)
      Feb-03 5:51:21 AM Life360 ERROR Exception UpdateInterval: System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_Life360.Plugin.UpdateLife360Devices(Object obj)
      Feb-03 12:55:19 AM Life360 ERROR Exception UpdateInterval: System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_Life360.Plugin.UpdateLife360Devices(Object obj)
      Feb-02 6:22:17 PM Life360 ERROR Exception UpdateInterval: System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_Life360.Plugin.UpdateLife360Devices(Object obj)
      I do not know if it is related to the above or not. The PI seems to be working.
      My update interval is 1 minute and can not think of anything that happened specifically at those times (such as a user leaving or arriving anywhere that would have triggered a webhook).
      I don't know if this is just their webservice timing out once in a while? I will turn on debug logging and let it run for a while. If it happens again I will PM you the log.
      -mda
        Ok. I will be looking into it. I'm working on converting some of the plugins to my base plugin library I use.
