Life360 Changes from 3.0.0.325 to 3.0.0.326
    sirmeili Can you please tell me what the changes are from 3.0.0.325 to 3.0.0.326? Also which version of the PI is correct? Is it 1.2.2.1 or 3.0.0.326? Thanks
    1.2.2.1 is an older code base written on in VB.net
    3.0.0.325 and 3.0.0.326 were the same. I just increased the version number (can't remember why).
    note that you can't do a direct upgrade currently from 1.2.2.1 to 3.0.0.325. It has to currently be a clean install.I'm considering writing an upgrade method for it, but haven't gotten there yet.
      sirmeili OK, thanks. I had 325 previously so I just went to 326. All working great. Also did you see my post about the grid view (HS4) showing just Inside and Outside? Not seeing this change from outside to inside and vice versa. Wondering if Address1 could be added either next to or below so we can see where someone is actually at.
