"MyZWaveParameter" plugin is a tool to simplify ZWave device parameter configuration. The plugin requires a working Homeseer ZWave plugin and network with ZWave devices to run.
It also requires XML files for the devices you want to use through this plugin.
The XML file requires 4 fields:
The info needs to be entered into the XML file:
Make sure you have the right XML for your specific Firmware version/Application version - parameters can have changed between the different version and using the wrong version/XML file can result in unwanted behavior.
XML Files are created from Template or download from other user who are willing to share their work.
XML files are stored under C:\Program Files (x86)\HomeSeer HS3\Config\MyZWaveParameters\
Here you will also find the template file to start creating your own XML's or to verify that the existing ones match your devices.
- Manufacturer
- Product Type
- Product ID
- Application Version
<xml version='1.0' encoding="UTF-8"> <Device name="Device Friendly name" url="URL to documentation - no & signs" Manufacturer="Hex code for Manufacturer" ProductType="Hex code for Product type" ProductID="Hex code for Product ID" version="Application version">
