Aeotec Home Energy Meter Gen5 (ZW095)
    Values required for HS3 are tagged with (Homeseer) AeonEnergyMeter-ZW095-A.xml
    Homeseer setup instructions https://help.aeotec.com/support/solu...-with-homeseer
    <xml version="1.0" encoding="UTF-8">
    <Device name="Home Energy Meter Gen5 (ZW095-A)" version="1.35" url="https://products.z-wavealliance.org/products/1289/configs" Manufacturer="0x86" ProductType="0x102" ProductID="0x5F">
    <Groups>
    <Group ID="1">Parameters</Group>
    </Groups>
    <Parameters>
    <Parameter name="2" group="1" access="rw" type="radio">
    <Setting values="0,1,2,3" default="0" size="1" />
    <Title>Energy detection mode configuration.</Title>
    <Description>Sets the reports for solar power.
    0 - Report Wattage and the absolute KWH value. (default) (Homeseer)
    1 - Report positive/negative Wattage and the algebraic sum KWH value.
    2 - Report positive/negative Wattage and the positive KWH value (consuming electricity).
    3 - Report positive/negative Wattage and the negative KWH value (generating electricity).</Description>
    </Parameter>
    <Parameter name="3" group="1" access="rw" type="radio">
    <Setting values="0,1" default="1" size="1" />
    <Title>Enable/Disable the function of parameter 4 and 11.</Title>
    <Description>When to report switch status changes to controller and associated devices.
    0 - Disable the function of parameter 4 and 11. (Homeseer)
    1 - Enable the function of parameter 4 and 11. (default)</Description>
    </Parameter>
    <Parameter name="4" group="1" access="rw" type="text">
    <Setting from="0" to="32767" default="32767" size="2" />
    <Title>Induce a automatic report of whole HEM.</Title>
    <Description>The threshold can be set from 0 to 32767 watt.
    Values: 0 to 32767.</Description>
    </Parameter>
    <Parameter name="5" group="1" access="rw" type="text">
    <Title>Induce a automatic report of Channel 1.</Title>
    </Parameter>
    <Parameter name="6" group="1" access="rw" type="text">
    <Title>Induce a automatic report of Channel 2.</Title>
    </Parameter>
    <Parameter name="8" group="1" access="rw" type="text">
    <Setting from="0" to="100" default="100" size="1" />
    <Description>The threshold can be set from 0 to 100 percent.
    Values: 0 to 100.</Description>
    </Parameter>
    <Parameter name="9" group="1" access="rw" type="text">
    </Parameter>
    <Parameter name="10" group="1" access="rw" type="text">
    </Parameter>
    <Parameter name="13" group="1" access="rw" type="radio">
    <Setting values="0,1" default="0" size="1" />
    <Title>Enable /disable CRC-16 Encapsulation.</Title>
    <Description>0 - Disable CRC-16 Encapsulation. (default)
    1 - Enable CRC-16 Encapsulation. (Homeseer)</Description>
    </Parameter>
    <Parameter name="101" group="1" access="rw" type="radio">
    <Setting values="1,2,4,8,256,768,2048,4096,65536,196608,524288,104857 6,1776384" default="2" size="4" />
    <Title>To set which report need to be sent.</Title>
    <Description>1 - Report Accumulated kWh of whole HEM.
    2 - Report Instantaneous Watts of whole HEM. (default)
    4 - Report Instantaneous Voltage of whole HEM.
    8 - Report Instantaneous Current (Amperes) of whole HEM.
    256 - Report Instantaneous Watts of Channel 1.
    768 - Report Instantaneous Watts of Channel 2.
    2048 - Report Accumulated kWh of Channel 1.
    4096 - Report Accumulated kWh of Channel 2.
    65536 - Report Instantaneous Voltage of Channel 1.
    196608 - Report Instantaneous Voltage of Channel 2.
    524288 - Report Instantaneous Current (Amperes) of Channel 1.
    1048576 - Report Instantaneous Current (Amperes) of Channel 2.
    1776384 - Report all reports on Channel 1 + 2 (Homeseer)</Description>
    </Parameter>
    <Parameter name="102" group="1" access="rw" type="radio">
    <Setting values="1,2,4,8,256,768,2048,4096,65536,196608,524288,104857 6,1776384" default="1" size="4" />
    <Description>1 - Report Accumulated kWh of whole HEM. (default)
    1776384 - Report all reports on Channel 1 and 2 (Homeseer)</Description>
    </Parameter>
    <Parameter name="103" group="1" access="rw" type="radio">
    <Setting values="1,2,4,8,256,768,2048,4096,65536,196608,524288,104857 6,1776384" size="4" />
    </Parameter>
    <Parameter name="111" group="1" access="rw" type="text">
    <Setting from="0" to="268435456" default="268435456" size="4" />
    <Title>Set the interval time of sending report.</Title>
    <Description>Interval Seconds.
    Values: 0 to 268435456.</Description>
    </Parameter>
    <Parameter name="112" group="1" access="rw" type="text">
    </Parameter>
    <Parameter name="113" group="1" access="rw" type="text">
    </Parameter>
    </Parameters>
    </Device>
    </xml>
