Is this still being updated/maintained? Is is possible to add arrows to rearange the order of the links similar to the way the events actions are done?
Link Editor
MeSteveTags: None
I'll take a look and see about adding that capability.--
Jeff Farmer
HS 3, HSPhone
MeSteve
Give this a try.Attached Files--
Jeff Farmer
HS 3, HSPhone
MeSteve
MeSteve
Jeff, I am seeing a wierd thing happen. I am trying to add another link, but when I hit the add button it is dropping the file extension.
You may be hitting the limit of the string for the ini file. If the total string is above 500 characters, the get ini function will chop off everything after 500.--
Jeff Farmer
HS 3, HSPhone
MeSteve
I read that, but I have a longer one that works. The link I am trying to add is for the map page of Weather XML, the WeatherXML Setup page is a longer string.
Edit: OK, I see, all the links together can only have 500 chrs
It's not 500 per link. The way HomeSeer stores the links is it combines them all into one long string. If you go over 500 total it truncates.
Example
PHP Code:links=Link 1 Text=/someurl.asp&Link 2 Text=/anotherurl.asp&Link 3 text=/thirdurl.asp
Jeff Farmer
HS 3, HSPhone
Pothead
Nice script but...
Is there any way to limit access to this on the web page when a user without admin rights is logged in? It seems any user can edit the links.
Perhaps I'm missing something.
