Support Area
  • Support Area
    This area is for the following:
    HS Links Editor - an editor for the customizable buttons that HS adds to the top of the web pages.
    Misc Plugin - 4 plugins in 1. Random phrase, Vehicle Tracker, Movie Manager Addon, and Restart
    Jeff Farmer
    HS 3, HSPhone
    Jeff, I'm using Random Phrase in HS3 - when the plugin starts I get:
    Dec-05 08:36:52 AM Random Error Conversion from string "" to type 'Double' is not valid.
    Is this an issue?
    Author of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
      I'll look into the error this weekend. If you could send me the hspi_Random.ini file that would help.
      Jeff Farmer
      HS 3, HSPhone
        Jeff, no internet access over the w/e - but here's the INI file you requested.
        [DeviceRef]
        PluginVersion=1988
        LastSpoken=
        [Settings]
        debugMode=1
        [dbConnect]
        sqlserveraddr=
        sqlservername=
        [Random]
        useHSDevice=False
        startupSpeak=BBC America
        delaySpeak=30
        startupHosts=
          For now set startupSpeak to 0
          [Random]
          useHSDevice=False
          startupSpeak=0
          delaySpeak=30
          I will add a way to set that without editing the ini file.
          Jeff Farmer
          HS 3, HSPhone
            Jeff, it seems any attempt to access the plugin throws this error. I tried the code:
            msg = hs.PluginFunction("Random","","random", new Object(){"GoodNight",False})
            And the log threw:
            Dec-17 10:02:11 AM Random Error Conversion from string "" to type 'Double' is not valid.
              Go to the Admin Settings page for Random and set the logging to high. Then try your script again and get me the log entries.
              I did just try this in a script and it worked so need to see some debugging to narrow down where to look in the code.
              Dim sVar as String
              sVar = hs.PluginFunction("Random","","random", new Object(){"BBC America",False})
              hs.WriteLog("Random",sVar)
              Jeff Farmer
              HS 3, HSPhone
                Enabled High Level for debug. Same issue.
                Dec-17 05:37:43 PM Random
                Dec-17 05:37:43 PM Random Error Conversion from string "" to type 'Double' is not valid.
                Dec-17 05:37:43 PM Event Running script in background: C:/Program Files (x86)/HomeSeer HS3/scripts/random.vb
                Dec-17 05:37:43 PM Event Event Trigger "Testing Test Random"
                Dec-17 05:37:43 PM Event Event Testing Test Random triggered by the event page 'Run' button.
                Sub Main(parm as object)
                Dim sVar as String
                End Sub
                I'm running v1.0.0.2
                  Do you have a category called BBC America? If not change what I posted to use a category that you have and make sure you have a couple of phrases in the category.
                  Jeff Farmer
                  HS 3, HSPhone
                    Is this an issue?
                    I've been getting the same exact error. No matter what I do, I always get the same.
                    I just set up a simple event to speak a random phrase. I have also tried setting a random string to a device. I have also tried the suggested script. All the same behavior as beerygaz.
                    Here is output from the log:
                    Dec-17 8:42:01 PM Random Array Rows: 14, Cols: 1
                    Dec-17 8:42:01 PM Random Array Rows: 0, Cols: 1
                    Dec-17 8:42:00 PM Sonos SpeakIn called for Device = 100, Text = , Wait=False, Host = $SONOS$Default$
                    Dec-17 8:42:00 PM Random Error Conversion from string "" to type 'Double' is not valid.
                    Dec-17 8:42:00 PM Random Array Rows: 0, Cols: 1
                    Dec-17 8:42:00 PM Event Event Trigger "Test Random Test"
                    Dec-17 8:42:00 PM Event Event Test Random Test triggered by the event page 'Run' button.
                    Please let me know what I can do to help debug.
                      This line in your log file tells me that there were 0 phrases found. However in the line right before that it shows 14 rows.
                      When I run a script I only get one line with the array rows info
                      Dec-17 9:45:07 PM Event Event Scripts Test Script triggered by the event page 'Run' button.
                      Dec-17 9:45:07 PM Event Event Trigger "Scripts Test Script"
                      Dec-17 9:45:07 PM Event Running script in background: C:/Program Files (x86)/HomeSeer HS3/scripts/test.vb
                      Dec-17 9:45:07 PM Random Array Rows: 2, Cols: 2
                      Dec-17 9:45:07 PM Random Get phrase between 0 and 2
                      Dec-17 9:45:07 PM Random BBC America, we put the Who in Doctor.
                      I put 1.0.0.2 in the updater. I added some more debug info to help figure this out.
                      Jeff Farmer
                      HS 3, HSPhone
                        I installed 1.0.0.2 and tried another test Here is the log:
                        Dec-17 10:55:09 PM Sonos Error Error in DoCheckAnnouncementQueue. 100 seconds expired since the announcement started and no end was received.
                        Dec-17 10:54:18 PM Random Array Rows: 14, Cols: 1
                        Dec-17 10:54:18 PM Random SQL=SELECT categoryID, categoryText FROM category WHERE isActive {0x3C3E} 0 ORDER BY categoryText
                        Dec-17 10:54:17 PM Random Array Rows: 0, Cols: 1
                        Dec-17 10:54:17 PM Random SQL=SELECT categoryID, categoryText FROM category WHERE categoryID = 5
                        Dec-17 10:54:16 PM Sonos SpeakIn called for Device = 100, Text = , Wait=False, Host = $SONOS$Default$
                        Dec-17 10:54:16 PM Random Error Conversion from string "" to type 'Double' is not valid.
                        Dec-17 10:54:16 PM Random Array Rows: 0, Cols: 1
                        Dec-17 10:54:16 PM Random SQL=SELECT categoryID, categoryText FROM category WHERE categoryID = 5
                        Dec-17 10:54:16 PM Event Event Trigger "Test Random Test"
                        Dec-17 10:54:16 PM Event Event Test Random Test triggered by the event page 'Run' button.
                        Dec-17 10:54:09 PM Random Array Rows: 14, Cols: 1
                        Dec-17 10:54:09 PM Random SQL=SELECT categoryID, categoryText FROM category WHERE isActive {0x3C3E} 0 ORDER BY categoryText
                        Dec-17 10:54:09 PM Random Array Rows: 0, Cols: 1
                        Dec-17 10:54:09 PM Random SQL=SELECT categoryID, categoryText FROM category WHERE categoryID = 5
                        Dec-17 10:53:41 PM Random Array Rows: 14, Cols: 3
                        Dec-17 10:53:41 PM Random SQL=SELECT c.categoryID, c.categoryText, c.isActive, count(p.phraseID) as phrases FROM category c LEFT JOIN phrases p ON c.categoryID = p.categoryID GROUP BY c.categoryID, c.categoryText, c.isActive ORDER BY c.categoryText
                        Dec-17 10:53:41 PM Random Array Rows: 14, Cols: 1
                        Dec-17 10:53:41 PM Random SQL=SELECT categoryText as ID, categoryText FROM category WHERE isActive = 1 AND categoryID IN (SELECT categoryID FROM phrases) ORDER BY categoryText
                        Dec-17 10:53:34 PM Random Array Rows: 14, Cols: 1
                        Dec-17 10:53:34 PM Random SQL=SELECT distinct c.categoryText, c.categoryText FROM category c INNER JOIN phrases p ON c.categoryID = p.categoryID WHERE c.isActive = 1 ORDER BY c.categoryText
                        Dec-17 10:53:19 PM TTS Speak: ():
                        Dec-17 10:53:19 PM Plug-In Finished initializing plug-in Random
                        Dec-17 10:53:19 PM Sonos SpeakIn called for Device = 100, Text = , Wait=False, Host =
                        Dec-17 10:53:19 PM Random Error Conversion from string "" to type 'Double' is not valid.
                        Dec-17 10:53:18 PM Random InitIO called, plug-in is being initialized...
                        Dec-17 10:53:18 PM Info Plug-in Random has connected successfully
                        Dec-17 10:53:18 PM Info Remote application or plugin has connected: 127.0.0.1:62226
                        Dec-17 10:53:18 PM Info Remote application or plugin has connected: 127.0.0.1:62225
                        Dec-17 10:52:12 PM Updater Install/Update of package Random Phrase was successful.
                          Jeff I do have the BBC America category with 3 phrases in it.
                          aperkin2 - I'm so glad I'm not the only one!
                          Here's the log from the 1.0.0.2 reinstall from the updater:
                          Dec-18 10:10:14 AM Sonos SpeakIn called for Device = 100, Text = , Wait=False, Host =
                          Dec-18 10:10:14 AM Random Error Conversion from string "" to type 'Double' is not valid.
                          Dec-18 10:10:00 AM Random Array Rows: 15, Cols: 3
                          Dec-18 10:10:00 AM Random SQL=SELECT c.categoryID, c.categoryText, c.isActive, count(p.phraseID) as phrases FROM category c LEFT JOIN phrases p ON c.categoryID = p.categoryID GROUP BY c.categoryID, c.categoryText, c.isActive ORDER BY c.categoryText
                          Dec-18 10:10:00 AM Random Array Rows: 15, Cols: 1
                          Dec-18 10:10:00 AM Random SQL=SELECT categoryText as ID, categoryText FROM category WHERE isActive = 1 AND categoryID IN (SELECT categoryID FROM phrases) ORDER BY categoryText
                          Dec-18 10:09:44 AM Plug-In Finished initializing plug-in Random
                          Dec-18 10:09:43 AM Random InitIO called, plug-in is being initialized...
                            I had the random phrase installed for my HS3 system, but never used it because I am using Dutch voices and English does not really sounds good with this voice
                            I was also seeing the double conversion error.
                            But what I think is weird, the plugin page for me is reporting I have 1.0.0.2 installed? I never initiated the upgrade?
                            Wim
                            -- Wim
                              aperkin2 and beerygaz,
                              Thanks for posting the log entries. I will look through them this evening and try to get this fixed.
                              w.vuyk
                              Did you try editing the phrases to be in Dutch? You can add, edit or delete the phrases and categories.
                              Jeff Farmer
                              HS 3, HSPhone
