Install of Misc Plugin
  • Install of Misc Plugin
    Don't know if it is me or my HS 2.3.0.19
    But it looks like I am missing something.
    ie-
    12/10/2012 12:19:40 PM ~!~Misc Plug-In~!~Add Table maintType
    12/10/2012 12:19:40 PM ~!~Misc Plug-In~!~Invalid Connect String
    12/10/2012 12:19:40 PM ~!~Misc Plug-In~!~Create Table maintenance
    12/10/2012 12:19:40 PM ~!~Info~!~Finished initializing plug-in Misc Plug-In
    12/10/2012 12:19:45 PM ~!~Database Item~!~Saving Device Misc Plug-In Misc Plug-in Version
    12/10/2012 12:19:45 PM ~!~Database Item~!~Saving Device Misc Plug-In Misc Plug-in Active Modules
    12/10/2012 12:19:50 PM ~!~Misc Plug-In~!~Misc Plug-In Found Plugin: HSTouch Server
    12/10/2012 12:19:50 PM ~!~Misc Plug-In~!~Misc Plug-In Found Plugin: weatherXML
    12/10/2012 11:58:34 AM ~!~Updater~!~Copying file: C:\Program Files\HomeSeer HS2\config\hspi_misc.ini
    12/10/2012 11:58:34 AM ~!~Updater~!~Making dir: C:\Program Files\HomeSeer HS2\docs\miscPlugin\
    12/10/2012 11:58:34 AM ~!~Updater~!~Copying file: C:\Program Files\HomeSeer HS2\docs\miscPlugin\miscPlugin.doc
    12/10/2012 11:58:34 AM ~!~Updater~!~Making dir: C:\Program Files\HomeSeer HS2\html\help\miscPlugin\
    12/10/2012 11:58:34 AM ~!~Updater~!~Copying file: C:\Program Files\HomeSeer HS2\html\help\miscPlugin\miscPlugin.pdf
    12/10/2012 11:58:34 AM ~!~Updater~!~Copying file: C:\Program Files\HomeSeer HS2\scripts\miscPlugin_install.vb
    12/10/2012 11:58:34 AM ~!~Updater~!~Running script install, please wait...
    12/10/2012 11:58:44 AM ~!~miscPlug-In Install~!~Misc Plug-In documentation exists in the \Docs\miscPlugin directory as miscPlugin.doc(MS Word)
    12/10/2012 11:58:44 AM ~!~Warning~!~VB.Net script exception, re-starting: Object reference not set to an instance of an object.
    12/10/2012 12:00:44 PM ~!~Updater~!~Making dir: C:\Program Files\HomeSeer HS2\data\miscPlugin\
    12/10/2012 12:00:44 PM ~!~Updater~!~Copying file: C:\Program Files\HomeSeer HS2\data\miscPlugin\random.mdb
    12/10/2012 12:00:44 PM ~!~Updater~!~Copying file: C:\Program Files\HomeSeer HS2\bin\miscPlugin\restartHomeSeer.exe
    12/10/2012 12:00:44 PM ~!~Updater~!~Copying file: C:\Program Files\HomeSeer HS2\data\vehicles\vehicles.mdb to C:\Program Files\HomeSeer HS2\data\miscplugin\vehicles.mdb
    12/10/2012 12:00:44 PM ~!~Updater Warning~!~Unable to install files, is HomeSeer running? Please exit it now if so. (Retry in 5 sec.)
    12/10/2012 12:00:49 PM ~!~Updater~!~Copying file: C:\Program Files\HomeSeer HS2\data\vehicles\vehicles.mdb to C:\Program Files\HomeSeer HS2\data\miscplugin\vehicles.mdb
    12/10/2012 12:00:49 PM ~!~Updater Warning~!~Unable to install files, is HomeSeer running? Please exit it now if so. (Retry in 5 sec.)
    12/10/2012 12:00:49 PM ~!~Updater Warning~!~Error installing file: vehicles.mdb , is file open?
    12/10/2012 12:00:49 PM ~!~Updater Warning~!~Detailed error:  0
    12/10/2012 12:00:49 PM ~!~Updater~!~Copying file: C:\Program Files\HomeSeer HS2\data\miscPlugin\vehicles.mdb
    12/10/2012 12:21:29 PM ~!~Misc Plug-In~!~runSelectAccess: SELECT ID, HSuserNames, vehicleYear, vehicleMake, vehicleModel, vehicleExtra, vehicleType, purchaseDate, purchaseMileage, currentMileage, licensePlate, VIN, insuranceCompany, insurancePolicy, notes, isActive, HSDeviceCode FROM vehicles WHERE ID =
    12/10/2012 12:21:29 PM ~!~Misc Plug-In~!~Syntax error (missing operator) in query expression 'ID ='.
    12/10/2012 12:21:29 PM ~!~Misc Plug-In~!~trackerVehicles: Conversion from string "" to type 'Integer' is not valid.
    I can't add any vehicles and get the errors above.
    I have attatched pics of the setup also.
    I have restarted now 3 times.
    Tim
    FB Page - https://www.facebook.com/pages/Capt-Tim/209398425902188
    HSTouch Layouts - https://www.facebook.com/media/set/?...5902188&type=3
    No, Im from Iowa. I only work in outer space. Captain Kirk
    Go to the page where Access is showing for the database. Click Save to make sure it got set.
    In the error logs I'm seeing one that says "invalid connect string" so I think it didn't save.
    Jeff Farmer
    HS 3, HSPhone
      I tried that, set debug to high, then navigated around the plugin's pages from the buttons provided and have this log section for you.
      Tim
      12/10/2012 3:22:31 PM ~!~Misc Plug-In~!~runSelectAccess: SELECT ID, HSuserNames, vehicleYear, vehicleMake, vehicleModel, vehicleExtra, vehicleType, purchaseDate, purchaseMileage, currentMileage, licensePlate, VIN, insuranceCompany, insurancePolicy, notes, isActive, HSDeviceCode FROM vehicles WHERE ID =
      12/10/2012 3:22:31 PM ~!~Misc Plug-In~!~Syntax error (missing operator) in query expression 'ID ='.
      12/10/2012 3:22:31 PM ~!~Misc Plug-In~!~trackerVehicles: Conversion from string "" to type 'Integer' is not valid.
      12/10/2012 3:22:47 PM ~!~Info~!~Event Trigger "BarmForGrafs"
      12/10/2012 3:22:47 PM ~!~Info~!~Running script in background: BDbarmValu4Grafs.txt
      12/10/2012 3:22:55 PM ~!~Info~!~Event Trigger "PostBarmGrafPic"
      12/10/2012 3:22:55 PM ~!~Info~!~Running script statement immediately: &hs.SetDeviceString "r3","<img src='/images/BDGraphs/BarometerLevel1174522036.png'>",true
      12/10/2012 3:23:06 PM ~!~Info~!~Event Trigger "TempGraf"
      12/10/2012 3:23:06 PM ~!~Info~!~Running script in background: BDGraphs.vben("Add","u60;1;u64;1;u65;1")
      12/10/2012 3:23:06 PM ~!~BDGraphs~!~The value(s), '18','16','6' in table 'TemperatureLevel2067389377' was/were added.
      12/10/2012 3:23:24 PM ~!~Info~!~Event Trigger "PostVisbGrafPic"
      12/10/2012 3:23:24 PM ~!~Info~!~Running script statement immediately: &hs.SetDeviceString "r5","<img src='/images/BDGraphs/VisibilityLevel1789874848.png'>",true
      12/10/2012 3:23:44 PM ~!~Info~!~Event Trigger "NetwrkMon"
      12/10/2012 3:23:44 PM ~!~Info~!~Running script in background: Jon00RCCNM_A.vben("network","")
      12/10/2012 3:23:53 PM ~!~Error~!~Calling GenPage for plugin, link: /misc?pg=trackerForm Error: Object reference not set to an instance of an object.
      12/10/2012 3:24:00 PM ~!~Info~!~Event Trigger "NoSewerWarning"
      12/10/2012 3:24:00 PM ~!~Info~!~Running script statement immediately: &hs.SetDeviceString "\9","<img src='/Wthrgrafs/leakseweroff.jpg'>",true
      12/10/2012 3:24:00 PM ~!~EventDelay~!~Current delay: 0.088 seconds [Delta: 0.032 Min: 0 Max: 7.148 @ 12/10/2012 12:32 PM] Last Event: NoSewerWarning.  Scripts running: Event Delay Measurement.vb
      12/10/2012 3:24:01 PM ~!~Info~!~Event Trigger "bbReminders"
      12/10/2012 3:24:01 PM ~!~Info~!~Running script in background: bbMyDay.txt
      12/10/2012 3:24:06 PM ~!~Info~!~Event Trigger "TempGrafMake"
      12/10/2012 3:24:06 PM ~!~Info~!~Running script in background: BDGraphs.vben("Make","u60;u64;u65;24;0;1")
      12/10/2012 3:24:15 PM ~!~Info~!~Remote client connected from: 127.0.0.1
      12/10/2012 3:24:19 PM ~!~BDGraphs~!~A graph for table 'TemperatureLevel2067389377' was created and placed in /html/images/BDGraphs.
      12/10/2012 3:24:22 PM ~!~Misc Plug-In~!~Field: module_Tracker=1
      12/10/2012 3:24:22 PM ~!~Misc Plug-In~!~Field: showBtnMileageForm=1
      12/10/2012 3:24:22 PM ~!~Misc Plug-In~!~Field: showBtnVehicleList=1
      12/10/2012 3:24:22 PM ~!~Misc Plug-In~!~Field: showBtnRestartHS=0
      12/10/2012 3:24:22 PM ~!~Misc Plug-In~!~Field: showBtnRandom=0
      12/10/2012 3:24:22 PM ~!~Misc Plug-In~!~Field: showBtnLinkEdit=0
      12/10/2012 3:24:22 PM ~!~Misc Plug-In~!~Field: saveSettings=Save
      12/10/2012 3:24:22 PM ~!~Misc Plug-In~!~Field: ref_page=misc_config
      12/10/2012 3:24:26 PM ~!~Info~!~Event Trigger "PrecipGraf"
      12/10/2012 3:24:26 PM ~!~Info~!~Running script in background: mlPrecip.txt
      12/10/2012 3:24:26 PM ~!~Info~!~Event Trigger "MonitorNetwork"
      12/10/2012 3:24:26 PM ~!~Info~!~Running script in background: Jon00RCCNM_Monitor.vben
      12/10/2012 3:24:26 PM ~!~Misc Plug-In~!~GenPage: name: pg = value: Tracker
      12/10/2012 3:24:28 PM ~!~Misc Plug-In~!~Field: pg=Tracker
      12/10/2012 3:24:28 PM ~!~Misc Plug-In~!~Field: dbType=1
      12/10/2012 3:24:28 PM ~!~Misc Plug-In~!~Field: sqlserveraddr=
      12/10/2012 3:24:28 PM ~!~Misc Plug-In~!~Field: sqlservername=
      12/10/2012 3:24:28 PM ~!~Misc Plug-In~!~Field: trackertoaddr=fungun@yahoo.com
      12/10/2012 3:24:28 PM ~!~Misc Plug-In~!~Field: trackerfromaddr=fungun@yahoo.com
      12/10/2012 3:24:28 PM ~!~Misc Plug-In~!~Field: saveTrackerMod=Save
      12/10/2012 3:24:28 PM ~!~Misc Plug-In~!~Field: ref_page=misc_config
      12/10/2012 3:24:28 PM ~!~Misc Plug-In~!~GenPage: name: pg = value: Tracker
      12/10/2012 3:24:32 PM ~!~Info~!~Remote client disconnected
      12/10/2012 3:24:34 PM ~!~Info~!~Event Trigger "PostRainGrafPic"
      12/10/2012 3:24:34 PM ~!~Info~!~Running script statement immediately: &hs.SetDeviceString "r6","<img src='/images/BDGraphs/TodaysPrecipLevel286493268.png'>",true
      12/10/2012 3:24:34 PM ~!~Info~!~Event Trigger "PostLakeTmpGrafPic"
      12/10/2012 3:24:34 PM ~!~Info~!~Running script statement immediately: &hs.SetDeviceString "r8","<img src='/images/BDGraphs/LakeTempF1747335183.png'>",true
      12/10/2012 3:25:05 PM ~!~Misc Plug-In~!~GenPage: name: pg = value: trackerVehicles
      12/10/2012 3:25:05 PM ~!~Misc Plug-In~!~SQL: SELECT min(ID), max(ID) FROM vehicles WHERE isActive = 1
      12/10/2012 3:25:06 PM ~!~Misc Plug-In~!~Array Rows: 0, Cols: 1
      12/10/2012 3:25:06 PM ~!~Misc Plug-In~!~SQL: SELECT ID, vehicleModel, HSuserNames FROM vehicles ORDER BY vehicleModel
      12/10/2012 3:25:06 PM ~!~Misc Plug-In~!~Array Rows: -1, Cols: 2
      12/10/2012 3:25:06 PM ~!~Misc Plug-In~!~SQL: SELECT ID, Type FROM vehicleType WHERE isActive = TRUE ORDER BY SortOrder
      12/10/2012 3:25:06 PM ~!~Misc Plug-In~!~Array Rows: 2, Cols: 1
      12/10/2012 3:25:06 PM ~!~Misc Plug-In~!~SQL: SELECT ID, HSuserNames, vehicleYear, vehicleMake, vehicleModel, vehicleExtra, vehicleType, purchaseDate, purchaseMileage, currentMileage, licensePlate, VIN, insuranceCompany, insurancePolicy, notes, isActive, HSDeviceCode FROM vehicles WHERE ID =
      12/10/2012 3:25:07 PM ~!~Info~!~Event Trigger "WndspdGraf"
      12/10/2012 3:25:07 PM ~!~Info~!~Running script in background: mlWndSpd.txt
      12/10/2012 3:25:07 PM ~!~Misc Plug-In~!~runSelectAccess: SELECT ID, HSuserNames, vehicleYear, vehicleMake, vehicleModel, vehicleExtra, vehicleType, purchaseDate, purchaseMileage, currentMileage, licensePlate, VIN, insuranceCompany, insurancePolicy, notes, isActive, HSDeviceCode FROM vehicles WHERE ID =
      12/10/2012 3:25:07 PM ~!~Misc Plug-In~!~Syntax error (missing operator) in query expression 'ID ='.
      12/10/2012 3:25:07 PM ~!~Misc Plug-In~!~trackerVehicles: Conversion from string "" to type 'Integer' is not valid.
      12/10/2012 3:25:10 PM ~!~Misc Plug-In~!~GenPage: name: pg = value: trackerVehicles
      12/10/2012 3:25:10 PM ~!~Misc Plug-In~!~SQL: SELECT min(ID), max(ID) FROM vehicles WHERE isActive = 1
      12/10/2012 3:25:10 PM ~!~Misc Plug-In~!~Array Rows: 0, Cols: 1
      12/10/2012 3:25:10 PM ~!~Misc Plug-In~!~SQL: SELECT ID, vehicleModel, HSuserNames FROM vehicles ORDER BY vehicleModel
      12/10/2012 3:25:10 PM ~!~Misc Plug-In~!~Array Rows: -1, Cols: 2
      12/10/2012 3:25:10 PM ~!~Misc Plug-In~!~SQL: SELECT ID, Type FROM vehicleType WHERE isActive = TRUE ORDER BY SortOrder
      12/10/2012 3:25:10 PM ~!~Misc Plug-In~!~Array Rows: 2, Cols: 1
      12/10/2012 3:25:10 PM ~!~Misc Plug-In~!~SQL: SELECT ID, HSuserNames, vehicleYear, vehicleMake, vehicleModel, vehicleExtra, vehicleType, purchaseDate, purchaseMileage, currentMileage, licensePlate, VIN, insuranceCompany, insurancePolicy, notes, isActive, HSDeviceCode FROM vehicles WHERE ID =
      12/10/2012 3:25:10 PM ~!~Misc Plug-In~!~runSelectAccess: SELECT ID, HSuserNames, vehicleYear, vehicleMake, vehicleModel, vehicleExtra, vehicleType, purchaseDate, purchaseMileage, currentMileage, licensePlate, VIN, insuranceCompany, insurancePolicy, notes, isActive, HSDeviceCode FROM vehicles WHERE ID =
      12/10/2012 3:25:10 PM ~!~Misc Plug-In~!~Syntax error (missing operator) in query expression 'ID ='.
      12/10/2012 3:25:10 PM ~!~Misc Plug-In~!~trackerVehicles: Conversion from string "" to type 'Integer' is not valid.
      12/10/2012 3:25:36 PM ~!~Info~!~Event Trigger "MaxSystemUptime"
      12/10/2012 3:25:36 PM ~!~Info~!~Running script in background: Maximum Uptime.vb
      12/10/2012 3:25:41 PM ~!~Info~!~Event Trigger "CurntCondPicDays"
      12/10/2012 3:25:41 PM ~!~Info~!~Running script in background: CurCond4hst.txt
      12/10/2012 3:25:41 PM ~!~Info~!~Running script in background: CurCondText.txt
        Tim
        12/10/2012 3:22:55 PM ~!~Info~!~Running script statement immediately: &hs.SetDeviceString "r3","",true
        12/10/2012 3:23:24 PM ~!~Info~!~Running script statement immediately: &hs.SetDeviceString "r5","",true
        12/10/2012 3:24:00 PM ~!~Info~!~Running script statement immediately: &hs.SetDeviceString "\9","",true
        12/10/2012 3:24:34 PM ~!~Info~!~Running script statement immediately: &hs.SetDeviceString "r6","",true
        12/10/2012 3:24:34 PM ~!~Info~!~Running script statement immediately: &hs.SetDeviceString "r8","",true
        I figured out the problem. I will work on a fix but I have a couple of school concerts to go to this week. It will probably be this friday before I can work on this.
        Jeff Farmer
        HS 3, HSPhone
          Cool, thank you much.
          Have fun at the concerts, I always did.
          Tim
            Posted 1.0.4 to the updater.
            I deleted all of the vehicles I was tracking in my development server and went through the pages to make sure they didn't error.
            You should be able to get it running now.
            I also removed the code that was registering for the log callback.
            I wasn't doing anything with it anyway.
            Jeff Farmer
            HS 3, HSPhone
              Runs as expected.
              Thank you,
              Tim
