"nice" shutdown of HS at reboot?
    Jeff,
    Does the restart plugin do a "nice" shutdown of HS before rebooting?
    Reason is that when I do have to do a restart of the OS, without shutting HS down first I often have corrupted ini files, causing HS to start with issues once the OS is back.
    It would be nice if I could do a restart of the OS, knowing HS will survive
    Wim
    -- Wim
    The version in the updater currently will not. It waits 90 seconds and then starts the shutdown/reboot.
    I do have a version that checks to make sure HS has closed then it starts the 90 seconds for reboot.
    When I get off work today, I'll package that up and put it in the updater. I will update this thread when its ready for download.
    Jeff Farmer
    HS 3, HSPhone
      .4 is in the updater. It tells HS to shutdown, then waits until HS has closed. Then is starts the process to shutdown or reboot the server.
      Jeff Farmer
      HS 3, HSPhone
        Jeff,
        Tested it and HS was shutdown before the reboot correctly. Thanks!
        Wim
        -- Wim
