No Event Actions available in HS4?
    I need an event which emails me when my ups battery is at 50% and, 10 minutes later, shuts down HS4. When I add the Restart plugin option to the event, there are no actions available for it. Ideas?
    HS4Pro on Windows 10
    One install with 2 Ethernet Z-nets
    2nd install with 1 Ethernet Z-net
    300 devices, 250 events, 8 scripts
    6 CT-100 tstats
    Serial IT-100 interface to DSC Panel with 8 wired zones
    18 Fortrezz water sensors & two valve controls
    When the plugin was installed there should have been a device created that show the version number. If you click on the device name there will be a tab labeled Restart. Make sure that the options for the Show Buttons are checked.
    Jeff Farmer
    HS 3, HSPhone
      All buttons are checked except for Shutdown HS Server (I don't want to mistakenly do that remotely as I could not restart it).
      6 CT-100 tstats
        The only thing I can think of is to stop and start the plugin. Then check the event actions.
        Jeff Farmer
        HS 3, HSPhone
          Hey Jeff, I disabled and re-enabled the plug-in with no success. Then I deleted it and reinstalled it. I got this msg at install.
          Here is the install log.
          9/23/2020 3:33:14 PM
          HomeSeer
          Updater
          Copying file: C:\Program Files (x86)\HomeSeer HS4\html\images\restart\Restart.gif
          HomeSeer
          Updater
          Copying file: C:\Program Files (x86)\HomeSeer HS4\HSPI_RESTART.exe
          HomeSeer
          Updater
          Copying file: C:\Program Files (x86)\HomeSeer HS4\bin\Restart\restartHomeSeer.exe
          HomeSeer
          Updater
          Copying file: C:\Program Files (x86)\HomeSeer HS4\Docs\restart\Restart.doc
          HomeSeer
          Updater
          Update hspi_restart.exe downloaded successfully
          9/23/2020 3:31:50 PM
          HomeSeer
          Info
          Plugin Restart with ID: and Instance: has disconnected
          6 CT-100 tstats
            I missed that you had put HS4 in the topic title. None of my plugins have been tested to work with HS4. I am still using HS3 and don't really have any plans on going to HS4.
            You will most likely need to uninstall it.
            Jeff Farmer
            HS 3, HSPhone
              Well, that’s a disappointment.
              6 CT-100 tstats
