Restart HS for HS3
    Restart HS for HS3
    I have split the Misc Plugin into 3 parts.
    The Restart HS section is now in the HS3 updater.
    Tracker and Random Phrase are done, just need to test the install. They should be in the updater next week.
    Restart HS allows you to
    * Restart HS
    * Reboot the Server
    * Shutdown the Server
    * Delay start HS on a server boot up
    Control is via a Web Interface or Event Actions.
    Jeff Farmer
    HS 3, HSPhone
    ill check it out!
    since i cant register my hs3.. have problems getting ticketing pwd set... so havent bothered.. im stuck in trial mode where you have to hit the trial button
      That sounds great.... How would you use this, some kind of message in the log? What will trigger the action?
      Hector
      Win.2003 OS, HS3
      MyTrigger,ACRF2,W800,Zwave
      AP800,Honeywell Stat
        The trigger can be anything that would trigger any HS event.
        You just set up the event action by selecting Restart Plugin in the Action section.
        Jeff Farmer
        HS 3, HSPhone
          Thks for rponding,Can you give a example on what scenario trigger can be used?
          Hector
          Win.2003 OS, HS3
            In my case, I am using an HS2 version as I have not gone production with HS3 yet.
            My server is starting to have problems with the network connector built into the motherboard. I have to reboot the server to get it working again.
            I also use UltraMon and have 4 websites setup to get checked. If all 4 websites go offline I consider the internet connection down and it sets a device to off. I can then trigger a server reboot on the device change.
            I know some users reboot their server once a week to keep it running good. You could trigger it based on a time and day of week.
            The other way I use it is that I have an icon in my windows startup folder. When I had an icon to HS I would run into issues where HS would start before the network had connected. This caused a couple of issues with a script that needed the connection. It would sometimes recover, other times it would not recover and would cause errors.
            I use this be setting a 45 second delay on the start of HS. That is enough time for the network to connect.
            Jeff Farmer
            HS 3, HSPhone
              Wow, this has great potential!!! Aim going to give t a try... Will this be a paid plugi?
              Hector
              Win.2003 OS, HS3
                This will be a free one.
                Jeff Farmer
                HS 3, HSPhone
                  Jeff, this looks good, I will surely be using it as well. Thanks for sharing your talent with us.
                    Hi Jeff
                    Is the Restart plugin 'Linuxed'?
                    I am not seeing it in the updater on my Ubuntu HS3 machine
                    Many thanks
                    James
                    cheeryfool
                      * Restart HS
                      * Reboot the Server
                      CF, can you use this for shutting down HS and then shut down server in a event of a power failure, if so how would you go about doing this? Could it be with a ups plugin of some sort? I know you have this for HS3, but do you also have this for HS2?
                      Hector
                      Win.2003 OS, HS3
                        Originally posted by cheeryfool View Post
                        Hi Jeff
                        Many thanks
                        James
                        No, it hasn't been set to run on Linux.
                        Jeff Farmer
                        HS 3, HSPhone
                          For HS2, the restart plugin was part of the Misc Plugin.
                          You could setup an event that triggers on the UPS plugins device going offline. For example, I use tenHSPower for my UPS in HS2. I have an event that triggers on Device tenHsPower UPS AC Line Status value becomes equal to Offline
                          The event action would then be: Misc Plug-In: Server Action: Shutdown Server
                          This would cover the shutdown of the server.
                          There isn't a way to have a plugin restart the server. You have to set that in the computer BIOS. When you boot up your server you should have a way to press a key to go into the BIOS settings. In the settings you may have an option on what the computer should do when power is restored. In my case I have it set to Auto Start on power restore.
                          So power goes out, the server gets shut down. When power comes back on, the server starts up.
                          I have a shortcut to the restartHomeseer.exe in my startup folder. This allows the server to get up and running before HS gets started. I have mine set to a 45 second delay.
                          Jeff Farmer
                          HS 3, HSPhone
                            But what happens to HS if you shut down server? HS is still running? Wouldn't It corrupt files to HS ?
                            Hector
                            Win.2003 OS, HS3
                              The way I wrote the functions is the restartHomeseer.exe is run.
                              Then the command to shutdown HS is ran.
                              So HS starts shutting down at the same time that the server is starting to close any other programs that are running.
                              Jeff Farmer
                              HS 3, HSPhone
