The version one will only change if there is an update in the plugin version. The other one should update based on which of the modules you select to be active. If you don't change that, then it won't update either.
With HS2, plugins had to be given a device code to use for their devices. Typically I would use a device that just displayed the version number of the plugin to keep my assigned code. So those 2 devices aren't really important other than to save the plugin code.
