Restart question
    Restart question
    Hi Jeff
    I have a question about restart. I have restart setup to start HS 120 sec. When I restart PC, HS start immediately when the desktop appears. Is this normal? Shouldn't the desktop appear then after 120 sec. HS startup?
    Hector
    Win.2003 OS, HS3
    MyTrigger,ACRF2,W800,Zwave
    AP800,Honeywell Stat
    Originally posted by Rotech View Post
    Hi Jeff
    Yes, it should wait 120 seconds if you are using a startup delay. Can you post a screenshot of where you have set the 120 second delay.
      Here you go... Now sorry if it's a dum question. Do you need to have HS3 added manually to you start up folder? Or does the plugin automatically start HS thru other means ? In my case I added it to the start up folder. (It was 180 no 120 sec)
      Hector
      Win.2003 OS, HS3
        I wonder when the count actually starts?
        Hector
        Win.2003 OS, HS3
          Bump
          Hector
          Win.2003 OS, HS3
            Bump
            Don't add HS3 to the startup folder...
            Add the restarthomeseer.exe located in the bin directory to your startup folder. The count starts from when restarthomeseer.exe starts running.
              OK, you're using Jeff Farmer's Restart plugin. I wouldn't think it would be able to delay the startup if you have a shortcut to HomeSeer in your startup folder. From his explanation: "You can add an icon to your Startup Folder that will allow you to set how many seconds before HomeSeer should be started. This allows windows to completely start before starting HomeSeer". You may have to see how to add that icon he is referring to. Maybe send Jeff (cfguy) a message.
              I use Startup Delayer because it works with Windows 8 more reliably than any other method I have tried - and it is free!
                Al answered while I was typing. Do what he said
                  Thanks for filling in for me and answering the question.
                  I had a late afternoon Doctors visit today and then took my wife out to eat afterwards.
                  Jeff Farmer
                  HS 3, HSPhone
                    I did as you stated and I got this warning, I am running win7.
                    Hector
                    Win.2003 OS, HS3
                      Here's what I did with windows 7. I left the restartHomeSeer.exe in the HomeSeer HS3/Bin/Restart directory.
                      1. Create a shortcut for restartHomeSeer.exe. To do that open Windows explorer and go to the Bin/restart directory. Right click on restartHomeSeer.exe. Then click on Create shortcut. When the shortcut is created it will be named
                      restartHomeSeer.exe - Shortcut
                      2. Right click on the shortcut and click Properties.
                      In the properties window click on the Shortcut tab and look for Start in.
                      It will have something like this:
                      "C:\Program Files\HomeSeer HS3\Bin\Restart"
                      depending on your install directory.
                      3. Remove the \Bin\Restart so that you have:
                      "C:\Program Files\HomeSeer HS3"
                      Do not change the path before the HomeSeer HS3 directory. It needs to point to your HomeSeer directory.
                      4. On the shortcut tab click on the Advanced button. Click on the checkbox to run as Administrator. Click OK to close the property windows.
                      5. Right click on the shortcut and click Rename. Change the name to StartHomeseer.
                      6. Move the shortcut to your startup directory. Right click on the shortcut and click Cut. Navigate to the following directory.
                      C:\ProgramData\Microsoft\Windows\Start Menu\Programs\StartUp
                      Paste the shortcut.
                      7. Check your Start Menu and confirm that StartHomeseer is in startup.
                      Jeff Farmer
                      HS 3, HSPhone
                        I followed your instructions but nothing happened, it got to the desk top but did not start HS.
                        Hector
                        Win.2003 OS, HS3
                          Paste the shortcut.
                          Could you please explain steps 3, 5, and 6?
                          Why remove the end of the path?
                          Why change the name?
                          What's wrong with just dropping the shortcut in the startup directory?
                          Originally posted by rprade
                            My understanding of starting up HS is that the Start In directory needs to be the HS root directory so that scripts will work properly when you have Imports statements at the top of the scripts.
                            No reason functionally. It was just to give it a more descriptive name.
                            There are several startup directories. The pathway that I posted is supposed to be for All Users. In my case I have Windows 7 set to auto login to a set username so I could place the shortcut in either directory.
                            I didn't know how Rotechs was setup so I went the All User route.
                            Jeff Farmer
                            HS 3, HSPhone
                              In an above post you moved the restartHomeseer.exe to the startup folder. Did you copy it back to the HS3/Bin/Restart directory?
                              I can tell you that the steps I posted do work. I have my computer setup that way running windows 7?
                              Jeff Farmer
                              HS 3, HSPhone
