Restart question
    #16
    Originally posted by CFGuy View Post
    C:\ProgramData\Microsoft\Windows\Start Menu\Programs\StartUp
    I did not remove the file from the Bin/restart folder, I just made a copy of it and modified as you described. The path that you describe is not available in C:\.
    What I did to add the shortcut was to open the start folder from the program page and past it there. But I don't see a C:\Programdata\ .......ect.
    Hector
    Win.2003 OS, HS3
    MyTrigger,ACRF2,W800,Zwave
    AP800,Honeywell Stat
      #17
      Did you make a copy of the exe file? Or did you make a shortcut?
      A copy of the file won't work.
      Jeff Farmer
      HS 3, HSPhone
        #18
        I right clicked the file and made a short cut. From there I modified and cut and paste. What is the correct way of testing it, maybe I am doing it wrong.
        Hector
        Win.2003 OS, HS3
          #19
          I executed the file from within the startup file and a pop up asked if I wanted to run this file and I hit ok. After a few sec. HS started up.
          Hector
          Win.2003 OS, HS3
            #20
            That is probably due to the User Account Control (UAC) setting.
            I don't leave that running on my server but how you set it is up to you.
            Jeff Farmer
            HS 3, HSPhone
              #21
              Jeff, you think by disabling the UAC it will work? This PC is new, also the OS is new to me. If you can tell what to do I can try to disable it.
              Hector
              Win.2003 OS, HS3
                #22
                I disabled the UAC and now it works, thank you Jeff
                Hector
                Win.2003 OS, HS3
