HS4 General Devices and SDJHealth Tab for devices not showing
    I have noticed that while using HS4 there isn't a "General Devices" section in the config page. Also, when looking at individual devices that are being monitored, I don't see a SDJHealth Tab to set different parameters.
    The 'General Devices' section was only added in the beta version of the plug-in. If you want to give that a try it can be installed from the beta section of the HS updater. The guide has been updated to the latest beta version and I plan on a general release fairly soon. The release version will probably be the current beta plus a small change so that the General Devices section is disabled by default.
    The General Devices features operate separately to battery device monitoring so don't interfere in any way with existing setups and the main purpose of the plug-in.
    As for your other point, as far as I am aware the HS4 Beta interface doesn't yet have a method of accessing device configuration tabs. There has been some discussion about this and I think the intention is that it will be added before the release version but I might be wrong. In the meantime it is possible to access the HS3 device interface pages in HS4 from which you have access to device configuration tabs and specifically the SDJ-Health tab for local configuration. I can't remember offhand the exact details of how and I am away from home at the moment. I do run an HS4 beta from time to time for testing purposes but it is not ready for a production system in my opinion. I will be back on friday and fire up my HS4 temporarily and give you instructions for accessing the SDJ-Health tab.
    I am waiting for HS4 to be much further progressed before I embark on producing HS4 native versions of my plug-ins. HS have made a pretty good job, so far, of ensuring that HS3 plug-ins continue to operate in HS4.
    Steve
      OK, I am starting to wonder if I should just go back to HS3 as I am having trouble with EasyTrigger (which I am trying out right now). Thanks for your help. I really like your plugin! Really gives me a lot of info and the battery % remaining is really useful!
        OK, I have checked and to access the HS3 user interface for devices from HS4 you add /deviceutility to the browser address. So if you are on your local network and the HS4 ui and your browser address is showing something like:
        http://192.168.0.6:8000/devices.html
        change it to
        http://192.168.0.6:8000/deviceutility
        and it will display the HS3 devices view.
        You can then access the configuration tabs and SDJ-Health tab just like if you were running HS3. This acts as a workaround until HS4 provides direct access to the device configuration tabs.
        You can also use Jon00's excellent 'Jon00 Links' utility to create easy ways of accessing pages such as this.
        I hope that helps.
        Steve
          Thanks Steve! That helped me re-find the HS3 deviceutility page that I had somehow accidentally stumbled into last week while meandering through HS4 so I knew it existed but I could not find it again. I had used it to tweak some device/status pairs that HS4 has trouble with and that also warns you WORK IN PROGRESS-DO NOT USE!
          Daniel
          HS4 Pro Edition 4.2.5.0 running on Lenovo ThinkCenter & Debian Linux
          Plugins: Z-Wave (via Nortek USB stick
          Home Assistant 2021.10.6 running on HA "Blue" ODROID-N2
          Add-ons: Android Debug Bridge, Duck DNS, ESPHome, File Editor, Glances, HA Google Drive Backup, InfluxDB, Log Viewer, MariaDB, Mosquitto broker, NGINX SSL Proxy, Node-RED, Portainer, SSH & Web Terminal, Samba, TasmoAdmin, UniFi Controller, Visual Studio Code, WireGuard, Zigbee2mqtt, Z-Wave JS to MQTT
          Integrations: AccuWeather, Alexa Media Player, Glances, Google Nest, HACS, HomeSeer, Insteon, IPP, Life360, Local IP, Logitech Harmony Hub, Mobile App, MQTT, My Garage, OpenWeather, Spotify, Tuya Local. Ubiquiti UniFi, Z-Wave JS
          Insteon: 2413S Dual Band PLM
          Zigbee: zzh! CC2652R Rev A
          Z-Wave: RaZberry daughtercard on RPi 1B via ser2net
