I set this up as per the instructions but it isn't notifying me when the batteries are low on devices. What am I doing wrong?
Help with devices not reporting
Originally posted by pcgirl65 View PostI set this up as per the instructions but it isn't notifying me when the batteries are low on devices. What am I doing wrong?
1. There is a well documented bug in the Z-Wave plug-in, which unfortunately HS still haven't addressed. This occurs sometimes after including a new device, usually, but not exclusively, using Z-Tools. The Z-Wave pi gets itself in a state which normally shows up as high, sometimes 100%, cpu activity. Whilst things generally carry on operating relatively normally one symptom is that it stops logging wake-up messages. This causes various problems but can be cured by restarting the Z-Wave lug-in or HS3. If you have SDJ-Health running it is fairly obvious when this bug occurs because you see your battery devices missing their wake-ups one after the other.
2. Unchecking the option to 'Log Poll and Wake-up Messages' on the Z-Wave>Controller Management page.
It is unlikely that you have done item 2 but best to just check that option is still checked. Then disable the Z-Wave plug-in, wait a few secs, and re-enable. You should then find that over the course of the next day your devices will wake-up and their status will change to Healthy.
Their is a hierarchy of warnings, of which Missed Wake-up, is the most critical so they are masking the low battery warnings. Once your Z-Wave pi is operating normally that should be corrected.
Let me know what you find.
Steve
Originally posted by pcgirl65 View PostThanks! I checked the "Log Poll" setting and it is checked. I have disabled z-wave and re-enabled it. I will report back in a day or two. I wonder if this is also why sometimes devices just don't fire for some reason and then they do?
Out of interest, the event you posted is just for low battery, do you also have an event for SDJ-Health triggered by Missed Wake-ups? That is the most important notification as it usually means the batteries are dead, whatever their apparent level might be. Personally I just use the one event for sending a pushover message triggered by any of the alerts, see example in the SDJ-Health guide. The message tells you what type of alert it is so it isn't really necessary to have separate messages. I have another event to email full reports.
Steve
Originally posted by pcgirl65 View PostI can't seem to find "had its value set to a value in the range of" in the Events. I think this is why I just did batteries. Can you tell me how you got that Condition?
> A Device's Value is..
then select:
> This device has its value set to...
then select the SDJ-Health Battery Health Root device
then in the 'is set to dropdown' select:
> (Enter a custom value or value range)
then you have two boxes where you can enter the start and finish of the range.
By the way, to be pedantic, it's a Trigger not a Condition
Steve
Originally posted by pcgirl65 View PostYes, that is true, it is a Trigger! Thanks, how often does this event tell you if batteries are low? Once a day?
You can of course use the HS event engine to do pretty much whatever you want. For example, if you want the previous event to also send you an alert every day then you would add a second Trigger (Or If) to the event.
> Or If 'The Time is this:' (set the time of day you want the message sending)
> And If 'The device has its value set and it is less than' (choose the SDJ-Health Root) 'Waiting'
Then, in addition to any time an alert is raised this event will also trigger every day at a certain time but only if there is an alert condition. If you wanted a report every day even if there isn't an alert condition then don't add the last condition (And If).
You will probably want to control the type of report which you can do in the Actions of the event by changing the Root device between 'Status', 'Short' and 'Full'. Refer to the example email event in the guide for how to do this.
The permutations are endless due to the power of the HS event engine.
Please feel free to post any questions.
Steve
Originally posted by pcgirl65 View PostThanks for the explanation. I will have to look at this closer. I am wondering, what does it mean if a device misses its wake up? And is there something that can be done to correct this problem. All of my devices except for one are now OK. 1 missed its wake up but the battery is at 80%.
I have some devices that consistently report nicely descending battery levels down to 0% before dying, but I also have devices that fail at random levels which can be as high as 90%. The pi can build up a history of reported battery levels for your devices which you can view and observe what kind of pattern different devices exhibit.
How you set alerts and how you use the information the pi provides is up to you and probably depends on how critical individual devices are. I have some devices that I don't replace the batteries until they die, some that I replace when they drop below a certain level, and some that I replace after a set number of days. You can configure the pi to alert you when any of these conditions occurs.
The guide does provide some information on this but is not comprehensive and everybody will develop their own methodology.
The pi can also use other monitoring methods for devices that are always awake, but that's another discussion.
I hope this helps.
Steve
