Event not reporting low batteries
Originally posted by pcgirl65 View PostNot sure what I am doing wrong with this event but it isn't reporting low batteries. I have had a couple of batteries completely die on me and I didn't get any notification.
Do you have the plug-in set to alert on low battery level, and what low value do you have set. Have you overwritten any of the global settings with local settings on the particular monitoring child devices for the devices that have dead batteries?
Can you post a screenshot of your SDJ-Health monitoring devices in list view, or preferably the HS3 legacy device manager view, Basically I want to see what the status string shows for the root and child SDJ-Health devices.
Also can you post a screenshot of your Battery Devices Config page in SDJ-Health showing how you have it set up.
Steve
Originally posted by Kigmatzomat View Post3% is probably too low. You probably want more like 15-20%. Imagine a flashlight: as the battery dies, the light gets dim. For an RF system, the radio gets too weak to report back.
0-Missed Wake-up
1-Low Battery Alert
2-High Discharge Rate Alert
3-Battery Life Alert
Steve
I believe I do have the plugin set to alert on low battery, unless I am missing something. I am attaching my battery config screen. I haven't changed any of the default settings. I can't remember how to pull up the HS3 device screen but I will include a screenshot of the SDJ Health Monitoring.
Originally posted by pcgirl65 View PostI believe I do have the plugin set to alert on low battery, unless I am missing something. I am attaching my battery config screen. I haven't changed any of the default settings. I can't remember how to pull up the HS3 device screen but I will include a screenshot of the SDJ Health Monitoring.
Have you tested your event? Manually trigger the event to make sure you get the Pushover message.
Let me know if that works and we can then investigate further.
Steve
I ran the event and I did get a pushover message that said All Devices are Healthy! Event Has No Message Body - Error
Then I ran the Notification Event and it said:
Low Battery Alert
Monitoring 11 devices1 Missed: 10 OK
I didn't receive any messages about the battery in the Kitchen Motion Sensor.
It doesn't tell me what battery is low.
Originally posted by pcgirl65 View PostI ran the event and I did get a pushover message that said All Devices are Healthy! Event Has No Message Body - Error
Low Battery Alert
Your notification event Pushover message subject is 'Low Battery Alert' which is why it states that even though the trigger is for any type of alert.
The Pushover message in your event doesn't have a body, only a subject, hence the error message.
If you want a message that gives you more details about the alerts and which devices are raising an alert configure the events as per the examples in the guide The example events send a pushover message with just the details of the latest alert followed by an email message with full details of all the monitored devices.
It is easy to change whether you send a Pushover message or an email and what information you display in the message. To change the information contained in the message configure your event to change the report type of the root device before sending the message, as per the email example. The example sets the report type to 'Full' which list all monitored devices whether they are healthy or not. For a Pushover message it is best to set it to 'Short' as this will only provide information in the report on any devices that have an alert.
Steve
Originally posted by pcgirl65 View PostI have set up another event like in your documentation to email me a full list. I ran it but I didn't get the email. I think it was blocked by gmail. I will have to look into that. This is the events now. Is there a way to display which battery is low in the pushover message?
Because you are running the event retrospectively the pushover message is only showing the latest alert which is the Missed Wake-up, not the previous Low Battery warning. You could manually run the triggers again by clicking the 'Retrigger' button on the SDJ-Health root device. This will clear any current alerts and then re-trigger them one at a time with a couple of seconds between. If your events are set up correctly they will be re-triggered consecutively.
If you want specific information to be sent in a particular way, e.g. email or pushover, let me know what and I will suggest how to configure your events.
The trigger you are using, i.e. the root device being set to a value in the range 0-3, will trigger on any of the alerts. If you want a particular event to trigger only on Low Battery events, for example, you would set the trigger to be the root device being set to 'Low Battery Alert'.
There is a lot of flexibility in what to trigger on, and what information to provide, which can make it confusing at first.
I hope that helps.
Steve
Originally posted by cowinger View Post
A couple of other things to consider.
I added a feature a while back so that you can automatically reset the report type to whichever format you want after a period of time. This is the 'ResetReportType' parameter at the bottom of the Battery Devices config page. This saves you resetting the report type at the bottom of your event.
I generally have the 'ResetReportType' set to 'Short' as I find this the most useful format for Pushover messages.
The other event I have on my system is to alert me when all the devices return to healthy. I find that useful, see below:
1597 being the RefID of the SDJ-Health root on my system.
Steve
