Log Monitor Report when using RegEx
    Steve, when a RegEx match occurs in the Log Monitor report the "Type" column shows "$1" for the match. Is that expected?
    It shouldn't do. Can you post your RegEx.
    Steve
      Steve
      Here's the RegEx:
      ^Error
      Just anchoring Error as the first thing in the "Type" string. If I just use "Error" I get a bunch of "Big5 Error" messages I don't want to see.
        Here's the RegEx:
        ^Error
        Try putting it in brackets
        (^Error)
        Steve
          That works, thanks! Still matches but correctly reports "Error" as the type.
            I’m not familiar enough with RegEx to know why the replace doesn’t work without the brackets. It doesn’t seem right to me so I think I’ll code a workaround that adds the brackets to the replace if they aren’t there. It should then work either way.
            Steve
              Steve
              Having refreshed my memory about RegEx and how I coded the highlighting in the plug-in, I realise why you need the brackets. Basically I use the first capturing group to replace the text whilst adding enclosing html to set the font to red. If you don't have any capturing groups in your RegEx then it replaces the matched text with $1. You can create a capture group within your RegEx expression, the simplest way being to enclose the whole expression in brackets, which makes the whole expression a capturing group.
              I was going to change the code to add brackets around the RegEx, if they aren't already there. However, that would remove the flexibility to create the capture group within a more complex expression. I have therefore not altered the code but added a note to the guide.
              If you use simple search words and phrases, leaving the RegEx box unticked, then the plug-in handles the highlighting automatically anyway.
              Steve
