Changed some battery devices from Philips Hue bridge to Conbee II not showing
    I recently moved all my hues bulbs and sensors to the conbee II bridge. However, they aren't showing up in SDJ Health. I have disabled and then re-enabled the plugin but still no luck. Any ideas? This is showing in the log:
    Warning - MType 104 . Monitoring child #1602 is no longer monitoring a device by Activity.
    Goto the Device page in HS4. Find one of your battery devices being managed by JowiHue. Select the child battery device:
    On the Feature page make sure the Device Type String says Battery (you can edit what it says):
    Give it a minute or two and SDJ should pick it up. The plugin scans all the device type strings looking for the word "battery" somewhere in the text to find eligible devices to monitor for activity.
      I'm not familiar with Philips Hue technology so I need a bit more information to understand your issue.
      When you say you moved the sensors to the conbee bridge, are they now new devices in HS or are they the same devices? That is, do the battery child/feature devices in HS have the same ref IDs as previously?
      When you say they aren't showing in SDJ-Health, ​what exactly do you mean? Monitoring devices not showing, devices not showing as available for monitoring in drop down lists, or something else?
      Steve
        Thanks, TC1 that seemed to work. I could now select them in the SDJ Health Battery settings.
          Glad it worked, I went through the same issue when using more and more zigbee battery devices, which under JowiHue didn't consistently get marked as a Battery type device.
