Is there anyway to get rid of the Tasker Connection Errors?
  • Is there anyway to get rid of the Tasker Connection Errors?
    Everytime I issue a command I am getting the following error messages, yet everything is working fine. I recall seeing a thread at one point that this is normal? Is it normal or is there something else going on here that I should be concerned with. Thanks.
    Jan-22 8:26:22 PM Tasker Plugin Error ----------------------------------------------------------------------
    Jan-22 8:26:22 PM Tasker Plugin Error Connection Error
    Jan-22 8:26:22 PM Tasker Plugin Error Sending local command failed: ()
    Hi, you probably have local ip and the phone does not respond on the local wifi request and use the cloud service instead. So no issue actually, if you only want cloud connection, try to remove the local ip.
    Tasker Plugin / Speech Droid
    Tonlof | Sweden
      The local IP is removed - the field is blank.
      The device I am trying to control is on the local network so should I put it's IP address in?
        It will always use cloud service if the android ip is not responding.
        You can check from any browser in your network to see if your device is listening for local commands by browsing to http://192.168.x.x:1817/?message=null
        If you see a json data string it works but if the phone is sleeping or doing something else it may not respond so test it several times with black screen / keylock etc.
        Tonlof | Sweden
          Great thanks. I put the local IP in as it is mounted on the wall and will never leave the house.
            I did make the changes below and I am still getting the errors? Tasker is working as far as I can tell. I just want to make sure I am not doing something wrong. Thanks.
              What do you get when you put 192.168.2.90 for the IP ?
              You can copy and paste.
              Eman.
              The People's Advocate.
                I get the same error with 192.168.2.90.
                i get the following when I try : http://192.168.2.90:1817/?message=null
                {"communication_base_params":{"type":"ResponseBasic","fallba ck":false},"sender":"APA91b_Key_deleted_byTonlof","result":" OK"}
                  What I can see is that you don't have any dots in your IP address.
                  Tonlof | Sweden
                    Did you see my other post? I tried with and without dots. Thanks
                      Sorry, I missed that.
                      You may test attached plugin, don't forget to make a full backup off homeseer.
                      Tonlof | Sweden
                        Thanks - this version seems to have eliminated the errors in the log.
