Need hand holding trying to run event
    I'm trying to run an event, and can't see to make it work.
    My task is set up like this
    1. Say
    Text Attempting to run event
    2. Variable Set
    Name %HSCommand to Talk Test
    Where the event name is Talk Test
    the Say command works but the event doesn't trigger.
    Am I missing a step?
    Don
    Yes. The IF part in the middle and the variable set would be first and the say stuff would be last.
    1 - name of event
    2 - if part (whatever and I use manual to test)
    3 - say what?
    Like so...looked up a test event here...
    [ATTACH]67425[/ATTACH]
    - Pete
    Auto mator
    Fanless IntelĀ® Celeron N3160 SoC 8Gb
      Hi Pete;
      I think I wasn't clear. I'm trying to get Tasker to trigger an event.
      There is a more serious misunderstanding on my part of not having something right as I can not change a device either.
      1 - name of event
      3 - say what?
      Don
        Duh...
        Apologies didn't see that you had posted under tasker plugin.
        - Pete
        Auto mator
          Don
            1. Say
            2. Variable Set
            I could be wrong and thinking of something else but I believe you don't need to have any spaces in your HS event name. Rename it to Talk_Test or TalkTest, something like that.
              Got it working, with much hand-holding by author.
              Don
