So it was kind of a pain having to set two sets of alarms if I wanted to get up at 5:30am, and I never did create a 6am wakeup event/virtual device...
Instead I have always been using "Turbo Alarm" on my phone and found that you can use it to trigger a Tasker app. I create a virtual device in HS which is "Conrad's Phone Alarm". So now when Turbo Alarm is triggered (alarm going off) it runs a Task "Alarm On", which does:
Variable Set: %HSSetdevicestring To On
Variable Set: %HSSetdevicevalue To 1
Variable Set: %HsRev To 249 (device Ref ID for "Conrad's Phone Alarm"
Variable Set: %HSCommand To DeviceUpdate
So this turns on the virtual device which then triggers this event. I also have an Easy Trigger range to only allow this event to happen in the MorningAlarm time range (Monday-Friday, 12am to 9am), I have to be home for the event to run (which means I'm in my bed) and it cannot be a holiday. The alarm may go off on my phone but the lights won't kick on if it's a holiday.
I also created another task for "Alarm Off":
Variable Set: %HSSetdevicestring To Off
Variable Set: %HSSetdevicevalue To 0
Which toggles the virtual device off when I shut off the alarm. This allows me to set the wake up time on the alarm with my phone and it'll turn on the lights when the alarm goes off. Just thought I'd share.
