help
  • jrjmpls7
    My screen doesn't look like that. See attached . I have the latest version (not beta). When I try to install beta version it fails Click image for larger version
  • Eman
    Originally posted by jrjmpls7 View Post
    the plugin is requesting a goo.gl key. Those are the terms you can't see in the upload I sent. I don't have a goo.gl key. The only key I have is the autoremote... key that you are talking about above;. Again-in the setup menu for the plugin, the terms that are already in the key box are the goo.gl terms. If I change them to the autoremote... terms and then put in the key I get an error. If I just put in the key and leave the goo.gl I also get an error.
    There were changes some time ago : https://forums.homeseer.com/forum/ul...87#post1300587
    First go to the beta section and download the plugin from there and once installed click on the down allow in the plugin settings. There should be three options to choose from.
    Once you input your number everything will come up ( Those are new types settings!) Plugin version 3.0.4.9
    Tip : I found a fault in the plugin == > Go to the URL settings in the Tasker Plugin and click on the goo.gl/ then click back on the autoremote.joaoapps.com/ (It's sticky!)
    Eman.
  • jrjmpls7
  • Eman
    Click image for larger version Name:	autoremote.png Views:	8 Size:	128.0 KB ID:	1364641 Attached is screenshot. Plugin asks for goo.gf key. The key Is have is an autoremote.joaoapps.com key. If I put the key part after the goo.gl/ in the plugin in I get a mistyped url error. If I replace the whole url with the autoremote.joaoapps... and key I get the same error. Can't figure out what key you are looking for.
    Hello jrjmpls7 ,
    I can't see your image is too small. But if I understand what you are on about, open up AutoRemote on your Android device and the number you see is your code (don't add the URL) because that is auto filled in where you choose in Tasker Plugin settings (yours should be "autoremote.joaoapps.com/) not the "goo.gl/" then in the box below insert the number (characters) you see at the last part / xxxxxxxxxxxxxxxxx (at the top of the QR code) then click save.
    Note : The name of you device in Tasker is what you named it in AutoRemote.
    If everything goes well, go through all your AutoRemote and Tasker apps and setup backups so you never have to stress again if change devices.
    Am sorry I wasn't able to see anything in your image (Tip : when you edit an image in Paint or other resize/scale it down to reduce the file size then when you attach it to the forum choose large)
    Eman.
  • jrjmpls7
  • Eman
    Please!
    Can you post here screen shots of what you are trying to do? You may be missing out something .
    Note : This video is comprehensive but can help to get to know how AutoRemote works : https://www.youtube.com/watch?v=8pXuo4JWTLQ (Pus you can also look here :https://joaoapps.com/autoremote/personal/ ) and I don't know if you've already seen this : https://docs.google.com/document/d/1Q4lnYZgYqFbfmesDabMhTZCRd8FfKQg92tRo96vbdGc/edit (may be old but still applies)
    Now if everything fails then it could be the version of Android you have (but don't hold me on that yet!) And all is not lost yet!. You can still do magic with other apps (hold that for now but just ask! How?)
    Eman.
  • jrjmpls7
    Plugin I have shows goo.gl as start of the url. If I put in the key portion or if I change the beginning to the autoremote.joaoapps.. like it shows in the autoremote app I get the misspelling error. I don't see any drop down menu to choose the autoremote.joaoapps.... Maybe this is only in the Beta version. I've tried several times to install it via updater,but it always fails.
    Please!
  • jrjmpls7
    Originally posted by Eman View Post
    Read this : https://forums.homeseer.com/forum/ul...l-format/page3
    You may jump to post #34 or else start at the beginning.
    Eman.
  • Eman
    Trying to put my new phone into tasker plugin. The autoremote url I get is https://autoremote.joaoapps....... When I use this I just get an error saying the url is mispelled. How do I fix.
    Also, I tried to install the beta but just get a message saying install failed. How do I fix?
    Eman.
  • jrjmpls7
    started a topic help
    help
