So I've installed Tasker and went through the procedure listed here in the manual:
Installed the plugin
Imported the predefined profiles
Set up the connection (first issue - I'm not in the local network, so local connection failed to set up as I couldn't choose proper network nor add SSID and password manually)
Installed autoremote (within AutoApps app), pasted link to the plugin,
It created device for my phone with a set of controls.
I've put a password into AutoRemote settings (same as in the plugin)
And that's more or less all I was able to do.
When I try to use controls from newly created device (i.e. "take a picture"), nothing happens.
The data is send, as when I look into autoremote log section I see: following info:
Received Message from Unknown: Text: "ref=292 photo=front=:="
Password: "mypassword"
So I tried other way (sending data from tasker to HomeSeer, simple task, turn a virtual device ON)
I've created a task within a tasker to control a device (ON/OFF virtual device, default settings, for OFF value is 0, for ON is 100)
See screenshot for how the task is created.
The task doesn't have any effect. When I try to run it (the play button at the bottom left), I have a following message from Tasker, titled "HTTP Request" (as far as I understood, it shouldn't stop the task from running)
If I'm correct, I don't see any data incoming in the HomeSeer log (any activity of the Tasker plugin after trying to run the Task in Tasker)
How to make it work?
