Help me I am stuck!!! (Solved)
    #61
    Originally posted by tonlof View Post
    Hi Steve, can you compare all the files with the files on your working Device?
    connection_method.txt
    myhs
    hs3.connection.dat
    s________@comcast.net
    k_____
    s_________.mine.nu:443
    on
    myhs.connection.dat
    s_____@Comcast.net
    s______
    connected2.homeseer.com
    on
    ssid.dat
    wifi address
    192.168.2.4:8080
    off
    I have tried this and still nothing on the tablet. FYI I change accessibility settings to on as per the instructions.
    By any chance could it be in the autoremote settings?
    Steve
      #62
      myhs
      hs3.connection.dat
      k_____
      on
      myhs.connection.dat
      s_____@Comcast.net
      s______
      on
      ssid.dat
      wifi address
      192.168.2.4:8080
      off
      Steve
      On this setup you are connecting with myhs service. Autoremote is only for the receiving part from hs3.
      Tasker Plugin / Speech Droid
      Tonlof | Sweden
        #63
        When I set the debug on the phone and test an event I get:
        s______@Comcast.net:s_______
        https://connected2.homeseer.com
        %httprespond
        On my tablet running the same event I get:
        I don't get %httprespond
        I also get an error message
        Wrong Code: PC Time 4:21:10 PM Android:UMT(-5) 5/23/2015 3:19:42|3687 seconds difference
        Then I get this:
        Commands1:Wrong code:PC Time 4:21:10 PM Android:UMT(-5) 5/23/2015 3:19:42|3687 seconds difference
        Hope this helps.
        Steve
          #64
          %httprespond
          Then I get this:
          Commands1:Wrong code[emoji14]C Time 4:21:10 PM Android:UMT(-5) 5/23/2015 3:19:42|3687 seconds difference
          Hope this helps.
          Steve
          I'm little confused now, I thought you said that you have got it to work with the phone but not the tablet?
          Check that your pc and tablet have correct time.
          Tonlof | Sweden
            #65
            Well don't be confused, that was the problem. My tablet's time was off over a minute and must have been causing the communication issues. The tablet is now working!!!
            I can't believe the time being off would have caused the issue. Sorry for not noticing that earlier.
            Thank you for all your help.
            Steve
              #66
              Steve
              Great, it's a security function. Each command from Tasker is only valid for X seconds. Can be changed in inifiles to longer value. Are your both devices working now?
              Tonlof | Sweden
                #67
                Yes they are both working fine. Now off to play with my phone and tablet and play with the GPS to try and make events with homeseer. Have you used your GPS signal to turn on and off lights?
                Steve
                  #68
                  Really great to hear, I have used GEO task but not to cotrol lights.
                  If you want to deside if your device is home or not I think it's better to check if you are connected to your home wifi.
                  Tonlof | Sweden
