Tasker Project Structure
This topic is closed.
This is a sticky topic.
  • Tasker Project Structure
    When you have import the project files you should have below tabs.
    HS3 Engine (Don't edit anything here)
    TASKS
    HS3Post: Handle communication to HS3 over different connection methods.
    SAY: Triggered when speech is used by hs3.
    Clear_Variables: Triggered from other task when needed to clear variables.
    Manual SpeechDroid: Used to trigger Speechdroid listen mode. Create a shortcut to your desktop if needed.
    Setup Connection (Run Me): This task must be run first time or if you need to change connection details.
    Setup Home Network: Triggered by Setup Connection, used to setup local connection.
    STROBE: Triggered when stobe command is called by HS3
    Turn Off Continuos Speech Recognition: Disable Autovoice Contiuos mode
    Turn On Continuos Speech Recognition: Enable Autovoice Contiuos mode
    VIBRATE: Triggered when vibrate is called by hs3.
    PROFILES
    HS Command trigger: Trigger HS3Post if variable %HSCommand is set.
    HS Device Trigger: Trigger HS3Post if variable %HSRef is set.
    Receiver For HS3 Tasker Push: Engine that listen for HS3 commands.
    Speechdroid: Speechdroid engine. Listen for trigger word "Android" (Activated by Continuos Mode)
    HS3 Addons
    TASKS
    AUTOLAUNCH: Will open app name when call the function from HS3.
    AUTONOTIFICATION:
    CALANDER:
    More to come
    Tasker Plugin / Speech Droid
    Tonlof | Sweden
Unconfigured PHP Module
