No Speech
  • No Speech
    Hi Tonlof,
    I don't seem to have speech after the latest update. I tried everything I could.
    I just can't have the speaker client working. The HS3 server is set to broadcast to all clients but nothing is coming out of the phone as before.
    Regards.
    Eman.
    The People's Advocate.
    Originally posted by Eman View Post
    Hi Tonlof,
    Regards.
    Eman.
    Hi Eman, I,m sorry but I found a bug.
    The fix is already on webserver so if you reimport HS3 Engine.
    Latest version should be 2015-08-20
    Tasker Plugin / Speech Droid
    Tonlof | Sweden
      Nice one man!
      It's so sweeeeeet!!
      Regards.
      Eman.
        Device Update
        Hi Tonlof,
        The device update stopped working after HS3 engine update so events don't fire. I hope it's not only me because no one is saying anything.
        Regards.
        Eman.
          Are you using the local connection method? In other words, have you entered any ip address in Tasker plugin for that device?
          Tonlof | Sweden
            Check if you have any STOP line in the SAY tasks.
            I notice even that I remove that line from my tasker and export it and place it in webserver it still was there.
            Have update the HS3 Engine again.
            Tonlof | Sweden
              I was about to post these findings when you went in first:
              Autoremote messages on the phone show: Can receive messages via wifi and Tasker local connection enabled
              But I noticed that at when setting up the old connection method Load SSID fails with: Warning could not connect to HS3.
              But the speech works
              I tried to remove and include the new local IP connection type but the events from the phone don't fire anymore. So what fixed the speech broke the device updates.
              Regards.
              Eman.
                Did you check if you had a STOP line in SAY task?
                Also try to run AUTOREMOTEWIFI manually, I have also added a Profile "Activate Local Connection every 15 mintes while wifi is connected.
                Check if you have this one.
                Tonlof | Sweden
                  It's connected at the moment from outside but will try again when I go home
                  Eman.
                    The STOP line in SAY task is not there.
                    Just updated the HS3 engine and now nothing is working. I don't know about other users' findings. But earlier I posted the when setting up the network connections Wi-Fi fails with: Warning could not connect to HS3 server
                    I think the extra local IP setting on the server side causes a collision.
                    Regards.
                    Eman.
                      Regards.
                      Eman.
                      Hi, when you said that nothing works. Do you meant all communication in both ways or only from HS3 to tasker? All tasks or only SAY?
                      My setup is up and running as normal with the latest versions.
                      Tonlof | Sweden
                        The STOP line has appeared when I run the SAY profile
                        Eman.
                          Eman.
                          So what happend if you remove it? Save changes and test?
                          Tonlof | Sweden
                            Nothing is working. I wish could go back to old versions but the files have been rewritten so it's not possible.
                            Eman.
                              Speech start working but events/Tasks don't fire or work. They worked remotely but not on Wi-Fi
                              Eman.
