Hello,
I am having a number of TTS issues with my setup, I have updated the plugin to the latest version, and also done an update of the tasker setup files. All of the config is set up, with local IP addresses, right usernames and so on. I also did a test with the vibrate and each device vibrates fine.
Anyway, when I try and send a TTS to the device(s), I can see the notification pop up on the screen which is great, except none of the text is spoken, regardless of how I specify the tags (e.g. <alarm> this is a test message).
Both devices have google TTS set as the default, and I tried both with the default:default settings in the say task, and also changing it to google TTS but still no luck.
How can I go about fixing this, as TTS is one of the main things I need from the tasker plugin
