Originally posted by skarragallagher
View Post
News
Tasker Plugin / Speech Droid
Tonlof | Sweden
Playing arround with some coding.
Is this what you are looking for, and in the future buttons on each child device.
Please let me know if you have any suggestions of naming the child, address etc.
Since the plugin always sends the deviceref and save it in tasker global variable %MyRef it may be usefull to call the tasker update by calling the address.
Ex. TASKER-%MyRef-NETWORK will call the device TASKER-2080-NETWORK
Root device may also be used as status of received command.
When sending new command it may store devicestring with "Sent command" and devicevalue 0
When tasker receive the command it will try to send hello back as confirmation and set root devicevalue to 1 and devicestring to Sent ok.Please excuse any spelling and grammatical errors I may make.
Tonlof | Sweden
I think you are almost there. The status, room, floor and time columns are missing as viewed in the HomeSeer web admin page. I don't know if this what I'm looking at.
Are you also going to include the apps mentioned at the beginning of this post as part of this project? That would be awesome! Having multiple apps sending data to one plugin just like the PHLocation plugin
Eman.TinkerLand : Life's Choices,"No One Size Fits All"
Eman.
Yes I crop the image since there was nothing to show on room/floor/time.
It will be apps in the future, I will focus on better connection between the device and hs3, better setup.
I am stuck with the stand-alone application that runs as a background service, it does not work with HS3 incorrect certificates so now I'm not sure if I will use it as engine instead of tasker. The orginal plugin has been messy and need to be rewritten so I have start coding Tasker plugin from scratch where I now have add root/child functions. I will also add events.
Is there any need of the pre-buttons on the tasker device if events is added?Please excuse any spelling and grammatical errors I may make.
Tonlof | Sweden
Tonlof | Sweden
Originally posted by Eman View PostWow!,
Are you also going to implement the video streaming? What you have done so far is cool!
Eman.
I will also look into event triggers, setup listen words to trigger an event from tasker.Please excuse any spelling and grammatical errors I may make.
Tonlof | Sweden
Hi tonlof,
Please keep up the good work and maybe one more question, is possible for situation for log level detection whereby if fatal or priority you can receive a message so you can act on it?
It would be nice if the messages were auto generated from error log itself.
I don't know if I'm asking too much.
Eman.Please excuse any spelling and grammatical errors I may make.
Tonlof | Sweden
Originally posted by tonlof View PostNot sure if I understand, are you talking about to have event trigger to act on hs3 tasker plugin error?
There was once a HS2 backup plugin which would send the last 10 lines of the HomeSeer log. Something to do with "hs.writelog" I don't know if this possible.
Originally posted by Eman View PostNo, I meant the HomeSeer log in general. So if an error occurs then HomeSeer would use the Tasker plugin to send the text message with the error log snippet.
There was once a HS2 backup plugin which would send the last 10 lines of the HomeSeer log. I don't know if this possible.
Tonlof | Sweden
Tonlof | Sweden
Originally posted by tonlof View PostCheck out Jon00 Homeseer Log Monitor for Homeseer 3
I will look again and see how it works. Nice one!
